450 single carb question...
lumbee
Postby lumbee » Wed Sep 26, 2012 3:04 pm
...hey guys, I have a 450 engine in a 250 scrambler. I am getting close to the first start up. I have a question on the carb. The carb is a Dellorto, and as the number VHB29AD stamped on it.
First, I wanted to verify, that this is indeed the correct carb for the engine. Also, what should the jetting be? I have the stock header with a generic 'dunstall' canister/exhaust. The exhaust has no baffle.
Additionally the carb has no filter on it, and I am planning on adding a pod of some sort. I am assuming I will get better streetability from a pod than a vstack that is wide open.
Any info ya'll can pass along is appreciated. Thanx!
71 250 Scrambler
6x 160 Monza Jr.
Re: 450 single carb question...
Postby ducwiz » Wed Sep 26, 2012 4:39 pm
on these pages
http://www.ducatimeccanica.com/parti_di_ricambio/pages/partidiricambio0335.htm
and
http://www.ducatimeccanica.com/singles_carb_set_up.html
you will find the desired information.
Without air filter and with open exhaust, the main jet should be 135 or 140.
Postby DewCatTea-Bob » Wed Sep 26, 2012 7:58 pm
By: lumbee...
" I have a question on the carb.
I wanted to verify, that this is indeed the correct carb for the engine. "
____ All 350/450 wide-case models (except Sebring) came with that same carb.model beginning late-1968/early-1969.
" what should the jetting be? "
____ Where were YOU when this thread -(click link below) was posted this past month ?
viewtopic.php?f=3&t=1186
amartina75
Postby amartina75 » Wed Sep 26, 2012 9:07 pm
1966 250 Scrambler
Postby Jordan » Wed Sep 26, 2012 10:56 pm
Just to confuse you, here's another (hopefully useful) page:
http://www.ducatimeccanica.com/67-70_si ... ual/4.html
