Control Cable
DanM
Control Cable
What size (watt) soldering iron is needed to tin the end of a control? I snipped the excess off the end of the compression release cable where it goes through the stop and need to tin it.
Re: Control Cable
I once bought a solder pot but had mixed results with it. For one thing, it's not very portable and it's not really very safe to be carrying a pot of molten solder around. It's fine if you can make cables at a workbench, but sometimes you need to string cables through something on the bike and tin the end of cable that's at the handlebars or some other awkward place.
That being said I saw a good mechanic make cables on a bike using a hand soldering gun.
I bought one for myself. They generally have a dual wattage determined by the trigger pull, and you'll want to use the high wattage.
I had a good degree of success with it making my own cables - until the last time I went to use the gun. I could not get the connection to hold for anything. It's a bit of an art; you have to splay the cable end and use some generous amount of flux for cleaning and heat transfer, you have to get the solder to fill the splayed end such that there is no way in hell it will pull back through the ferrule. At the same time I am told if you heat it too long the solder wicks too far up the cable and makes the cable inflexible and brittle in the area before the ferrule.
I probably am not using the write terminology, but on clutch cables there is usually a large ferrule that the cable feeds through, then if feeds through some smaller ferrule that you solder onto the end of the cable to prevent it from pulling through.
I think how well you need to do has a lot to do with the amount of stress placed on the cable. Clutch cables are the worst, maybe brake cables after that. Your cable doesn't sound like it will have to endure a high amount of stress.
Re: Control Cable
You can buy small gas burners that have a cigerete lighter as the fuel and have a good pointy flame.
These aren't much bigger than a cigerete lighter and get easily hot enough to solder cables.
Also small enough to pack in your tool bag for unexpected cable repairs by the side of the road.
DanM
Re: Control Cable
I've got one of the dual temp soldering guns but thought it would be difficult to get the cable to a uniform temperature. I thought it would take a large soldering iron like the one pictured to heat the cable.
I'll give the soldering gun a try.
DanM
Re: Control Cable
graeme wrote:You can buy small gas burners that have a cigerete lighter as the fuel and have a good pointy flame.
Thanks for the suggestion but the cable end is attached to the cylinder head and thats too close to the gas tank and carburetor for an open flame.
Re: Control Cable
Would a bicycle type crimped cable inner end suit?
DanM
Re: Control Cable
Jordan wrote:Would a bicycle type crimped cable inner end suit?
I'll have to stop by a bicycle shop and look. I'm not familiar with those.
Re: Control Cable
The one on the left.
DanM
Re: Control Cable
Jordan wrote:The one on the left.
Thanks for the picture Jordan. Saved me a trip to the bicycle shop. I don't think that will work for me. The compression release cable has to thread through a hole in the cylinder head fin and then through a hole in the stop.The compression release is used only on non-desmo 350's and 450's.
Users browsing this forum: Boxprod and 114 guests
