Replace Clutch Plates?
blaat!
Postby blaat! » Fri Jul 13, 2012 11:43 am
The steel plates of my clutch have burrs (see photo).
To me, they feel a bit loose on the center hub, but all the wear seems to be in the plates as the center hub is clean with no ridges worn in. Strangely, the friction plates are in great condition and total thickness of the clutch matches the starting spec of 27mm, nowhere near the wear limit of 25mm. I'm doing a total rebuild of the engine and want it to run properly with no clutch issues. Should I go ahead replace the clutch plates, or just clean off the burrs? Is there a limit to the amount of play between the steel plates and hub? Seems like there would be no way to measure the rotational movement, it would just be a guess. Am I risking doing damage to the center hub?
Thanks!
Re: Replace Clutch Plates?
Postby Jordan » Fri Jul 13, 2012 12:22 pm
Wow, that looks like very soft steel was used for the driven plates, the way the engaging tabs have widened sideways.
I don't think it's a big problem if there's some rotational play. There's a lot more backlash in the gears' dogs after all. Old books on motorbike maintenance advised filing of clutch slots wider to remove ridging.
Users browsing this forum: Google [Bot] and 85 guests
