Front wheel off set
lloydy1
Front wheel off set
Postby lloydy1 » Thu Apr 19, 2012 7:54 pm
Hi, could someone advise me please of the correct off set for a 18" Borrani rim? which is fitted to my Ducati Mach1, which I am rebuilding. The reason I ask is, I have rebuilt the wheel taking the measurement from the hub and rim before the strip down and now I have fitted the wheel back on the bike it is not sitting centre of the folks. It is 2.5mm to far to the right as you look at the bike from the front. I am kicking myself a bit because I presumed it was correct before the strip down and you know what they say about presumption! :cry: . I have placed a spacer between the folk leg and the brake plate which corrects it making it central, but the lug is not fully home, which I am not happy with :( Can someone point me in the right direction?
Re: Front wheel off set
Postby JimF » Thu Apr 19, 2012 8:28 pm
If I understand the problem, I believe that the wheel rim is supposed to be tucked tightly into the brake boss on the fork leg. Then the rim is supposed to be laced with an offset in the spokes so as to center the rim and the tire within the fender.
Your solution might work, but I would feel better knowing the brake boss is fully engaging the brake plate.
Here's a similar thread....
viewtopic.php?f=3&t=63&p=349&hilit=front+wheel+offset#p349
Other opinions may vary.
lloydy1
Postby lloydy1 » Thu Apr 19, 2012 8:43 pm
Okay, so I would need to realign the rim by the 2.5mm on the hub, thus fully engaging the lug and centring the tyre for it to correct? thanks for that.
Postby JimF » Thu Apr 19, 2012 8:46 pm
I beleive theat's correct, but wait a day or two for other opinions - I could be wrong.
Postby Eldert » Thu Apr 19, 2012 8:47 pm
another option would be to put a spacer between the hub and the brakeplate
lloydy1
Postby lloydy1 » Thu Apr 19, 2012 8:52 pm
Eldert wrote:another option would be to put a spacer between the hub and the brakeplate
I have placed a spacer, but my concern is that the lug is not fully home and I don't feel it is right.
Postby Eldert » Thu Apr 19, 2012 9:02 pm
no not between the fork lower and the brakeplate but inside between the hub and the plate
lloydy1
Postby lloydy1 » Thu Apr 19, 2012 9:06 pm
Okay, I could give that a go, thanks for that.
jbcollier
Postby jbcollier » Fri Apr 20, 2012 2:20 am
The front wheel on a Duck single is symmetrical twit the hub flanges.
Please remember that adding spacers will splay your forks.
lloydy1
Postby lloydy1 » Fri Apr 20, 2012 4:53 am
jbcollier wrote:The front wheel on a Duck single is symmetrical twit the hub flanges.
I see what you are saying, but would it not correct itself on the pinch bolt side due to the free float before you tighten it up?
Dave
Users browsing this forum: No registered users and 85 guests
