1976 350 Road
Re: 1976 350 Road
Postby Duccout » Fri Apr 21, 2023 6:24 am
Hi George,
Lacey Ducati sells the aluminium base gaskets in various thicknesses, including a 1.5mm, so it would be easy to lower the compression and as long as you are not bothered about performance, it would be easy to take it down pretty low. More learned people than me can advise what you would need to go to 7:1 or 8:1.
Interestingly, my brother-in-law recently did this to his Triumph 750 because he could no longer kick it over, but he swapped to low compression pistons.
Re: 1976 350 Road
Postby George » Fri Apr 21, 2023 7:37 pm
Thanks for that Colin. I am thinking of fitting 1.5mm plus one gasket either side of alli compression plate increasing barrel height by 2mm. Not sure what difference it will make to compression has anyone tried this. Worth a try. Not sure if Nigel's fit Mototrans, I have sent him and email to confirm. Unless you could confirm they fit,
Re: 1976 350 Road
Postby Jordan » Fri Apr 21, 2023 11:50 pm
Data from instruction manual for 1968 350SCR.
Swept volume 340.2cc
Compression ratio 10:1
Bore 76mm
It can be worked out that the combustion chamber volume is 37.8cc
A 2mm added spacer will increase the chamber volume by 9.073cc
Adding that to the standard volume makes it then 46.873cc
That results in the new compression ratio 8.25:1
Re: 1976 350 Road
Postby Eldert » Sat Apr 22, 2023 8:49 am
Hi George
did you try a 450 kickstart lever ? they are a little longer .
by adding spacers under the barrel you have to much squish and therfore no swirl to help with burning the mixture .
i the roof of the piston is thick enough i would mill the piston a little lower .
Re: 1976 350 Road
Postby Duccout » Sat Apr 22, 2023 12:20 pm
Hi Eldert,
Will milling the piston affect the engine balance in a bad way?
Re: 1976 350 Road
Postby blethermaskite » Sat Apr 22, 2023 1:42 pm
Could you not just put a 350 sebring piston in it ????? I think it was around 8.5 to 1.
(other) George
Re: 1976 350 Road
Postby George » Sat Apr 22, 2023 6:52 pm
Thanks for all the replies. Sorry for the delay answering I have just got home from Stafford bike show.
I am going to fit the 2mm spacer under barrel and see if I can kickstart. If yes I will ride it for a while to let it settle down after engine rebuild and then see where I go from there.
At show I tried for a straight swop with a green frame 750 SS but for some reason owner was not interested. 8-)
Re: 1976 350 Road
Postby LaceyDucati » Sat Apr 22, 2023 8:47 pm
Hi George,
Eldert's advice is correct, running a large squish is not ideal and machining the piston crown would be better. You should also consider that raising the cylinder disengages the bevel coupling, potentially leading to less driving surface and increased wear. The weight difference in machining the crown is unlikely to make a significant difference to the balance and anyway many original cranks are miles out anyway. A Sebring piston may work, but the deck height and squish angle are different, would need some checking/adapting. The Longer kickstart that Eldert mentions is also found on the 350 Condors.
Maybe a 2mm base shim may be worth trying just to prove a point. I'm sure it will be possible to effect a solution, maybe give me a call if you need some suggestions/help.
Re: 1976 350 Road
Postby George » Sat Apr 22, 2023 9:18 pm
Thanks for the advice Nigel. I will order spacer and give that a try first. A cheap way to prove a point. Of course the fault is with the owner not the bike. As mentioned before my younger fitter friend has no trouble starting it.
Re: 1976 350 Road
Postby Jordan » Sat Apr 22, 2023 11:46 pm
Is an electric starter worth considering?
