Can stock alternator produce more volts and power?
Re: Can stock alternator produce more volts and power?
Postby wcorey » Wed Aug 31, 2011 4:02 pm
I might be missing the point. It seems to me that this thread should be the distillation of the other thread.
Mike, I think you are missing what this is about. This is just a start,we still have every intention of continuing on with the distillation of the big alt mod thread but this material had to go somewhere and here it is. As far as I know nothing of the original will be deleted, only moved, then new threads will be started to consolidate the 'good info'.
If you have alternate suggestions of what to do with it, I'm sure Bob can accommodate them. My feeling was that this particular section of the discussion was a continuation of the one in the '6 coil alt in a n-c 250' thread and should be moved there (as an easy solution) or if someone really wanted to work at it, separate that material as well into this thread...
I'm continuing the discussion of how best to proceed with the alt mod/testing material in that thread.
Misunderstood Thread-title ?
Postby DewCatTea-Bob » Wed Aug 31, 2011 5:56 pm
MotoMike wrote: It seems to me that this thread should be the distillation of the other thread.
____ Why is that Mike ? _ What's making you think so ?
The reason (for your thought) should not be inspired by the particular given title of this thread, as it comes from YOUR very-own post at the beginning of this thread.
__ The motive for creating this separate thread came from yourself (originally in the first-place),, and also (much later) suggested by Bill, so as to cut-away excess-fat from the overly extended-thread (from which this new-thread's posts were taken-from).
Bill & I, (as well as assumed most everyone-else), had agreed that the original/extended-thread needed to be cut-down in size as much as possible, and that this rather unrelated long batch of posts needed to be removed (to elsewhere),, so that the main-bulk containing Bill's extensive testing-work on the 6-pole alt.stator could then be left more homogenized.
__ Perhaps (for some reason) you were expecting this particular thread to be the very-one that's expected to contain just that which you've mentioned you were expecting this-one to contain,, however unclear why you expected such of THIS thread, of all others.
Sorry to disappoint you but, this thread is merely just the location where a sizable-bit of the excess-fat from the original/extended-thread, got dumped-out to.
__ I'm afraid it may be a fair while longer before you find that which you were actually expecting to be found here.
Users browsing this forum: No registered users and 95 guests
