250 N/C cyl head refurb
Re: 250 N/C cyl head refurb
Postby Bevel bob » Mon Nov 11, 2024 4:50 pm
After a rebore ,too much idling will glaze the bore. Also a too slow idle will starve the motor of oil. Give it some shortish bursts of work to set the rings. Once run in keep the motor spinning well . The big end will thank you.
Mike
Postby Mike » Mon Nov 11, 2024 5:05 pm
Thanks Bob - how my brain interpreted that...
Don't waste time letting it idle, get out there and ride the nuts off it
:lol:
Postby themoudie » Mon Nov 11, 2024 8:30 pm
Aye Mike :lol:
Yes, as Bob suggests, keep it spinning 5,000rpm ceiling and not lugging. 20W-50 oil for 20 - 50 miles, then dump it and check for "sparkles"! Run a magnet over the drainings as well. I flush the sump out, using aerosol brake cleaner, with the machine on the sidestand to drain, and let it evaporate, afore refilling, with more 20w-50. Change oil again at 200 - 250 miles, same clean down and check, refill with 20W-50 and run to 1,000 miles, with short bursts of max revs (8,000 - 9,000rpm). Now drain and flush, then fill, with your regular running oil of choice.
My 450 didn't really free off until after about 1,500 - 2,000 miles of running.
