Noise issues on 350 Scrambler engine
Re: Noise issues on 350 Scrambler engine
Hi Rocla, It is possible to set the top bevels with the head off, the shaft tunnel needs to be installed to the head and the shaft centralised in the tunnel with a bush or 1/2 inch drive socket or similar.The bottom bevel bearing holder can usually be moved up by tapping the center of the gear from below with a drift/alloy punch,and then levered out with care, heat the case can help.
Rocla
Hi Bob,
I've succeed in moving the bearing housing without the tool but anyway, a problem remains: how to move the vertical pinion? The crankshaft axle empedes that, by few in fact. I think it requires to remove metal from the right engine housing, just 1 cm. Do you confirm?
Anyway, I've started a new topic, I think it deserves that...
Hi , If you remove the circlip the bush comes up,leaving the gear( and its shims) in the case ,it can be fiddled out (if i remember right !) once the bush is out.Dont damage the cases!.If not perhaps it can stay in.
Rocla
No, there is no space enough. It was confirmed by a oldtimer Ducati specialist... (goto the new topic)
