Making A Little Progress (with pics)
Re: Base Circle Measurement
Postby DewCatTea-Bob » Sun Apr 22, 2012 5:09 am
" I came up with 23mm as the base circle measurement. "
____ Okay then, (that's 905.5-thousandths), this measurement confirms what seems to be visible in your pix of the cam,, that larger base-circle indicates the n-c red-cam. _ (As the dia.size of the base-circle on the w-c.Mk3-camshaft is almost as small as the shaft-stock itself.)
" this same head has the coil spring conversion on it. So that would point to someone messing around with it, maybe making a cam swap more likely? "
____ Right, I tend to agree (with that sensible logic).
Users browsing this forum: No registered users and 156 guests
