My 350 Vento
Re: My 350 Vento
Postby themoudie » Mon Aug 11, 2025 9:12 pm
Aye Sam,
and sandblasted the engine parts
I hope that you are able to give every little orifice a thorough clean, so as to remove ALL TRACES of the blasting medium! :evil:
I too had a pair of crankcases vapour blasted and after receiving them back, found that all the threaded holes, oilways and nooks and crannies still had traces of impacted blasting medium in them! Inspite of having been assured that the cases had been thoroughly cleaned after the blasting process. It then took the best part of 8 hours to pick out the impacted medium, then using an airline at 80 psi to blast everything through, until no medium appeared to remain. I then hot detergent washed the cases and yet more medium appeared, so repeated the process, with clean water flushing, a further 5 times before the water ran clean! I am still wary of there being the odd stray bit of blasting media in the cases. :evil: Although that might be a bit paranoid. :(
Previously, I have always just cleaned everything down with paraffin, then brake cleaner, before hot detergent washes until the water ran clear. A lot cheaper and less stressful than medium blasting, regardless of the media used.
Good health, BillR
Re: My 350 Vento
Postby ranton_rambler » Tue Aug 12, 2025 11:40 am
My cases were given an initial wash in the parts cleaner at work, and then had a cycle in the dishwasher at home.
The only problem was that they came out a dull grey, so needed some manual effort to bring back the correct colour.
I was subsequently told that I should have put citric acid in the machine rather than normal dishwasher detergent, although have never tried it again.
SamC
Re: My 350 Vento
Postby SamC » Thu Aug 14, 2025 7:14 pm
Sorry, I don't use sand for the blasting but baking soda (bicarbonate de soude en français)
Users browsing this forum: Boxprod and 45 guests
