1976 350 Road
Lost Soul
Re: 1976 350 Road
Postby Lost Soul » Mon Jul 25, 2022 8:22 pm
Hi
Another person rebuilding a 350 road. Nearly finished mine with some good hints and help from Jon.
Will be interesting to see it once up and running. I am on the herts/Essex border. Could be a Ducati single fest. :)
Re: 1976 350 Road
Postby George » Mon Jul 25, 2022 8:56 pm
Lost Soul wrote:Hi
It would be interesting to know what carburettor you have on the bike and the year of manufacture of your 350 Road.
I also have a 200cc Elite as does my friend. We live in South Essex. When you have bike running and you have found your soul we could meet up
Lost Soul
Re: 1976 350 Road
Postby Lost Soul » Tue Jul 26, 2022 9:28 am
It is an Amal R 930 417
Re: 1976 350 Road
Postby George » Tue Jul 26, 2022 2:52 pm
Lost Soul wrote:It is an Amal R 930 417
Any photos of your Bike.
Lost Soul
Re: 1976 350 Road
Postby Lost Soul » Wed Jul 27, 2022 6:49 am
Just test fitting exhaust, being a pain as it sits really close to the down tube.
Tried a couple of different downpipes. The 250/350 pipe I originally bought does not have enough drop, it does not clear the footpegs so I bought a 350 scrambler one which has the right length, but even without an exhuast gasket it only has about 1 mm clearance from the frame downtube.
Waiting on a couple of part like pertol taps, both mine are leaking and then hopefully I will get to try firing it :)
One question on the Carb. I looks like the choke is closed when the lever is closed and open when the lever is pulled. Seems strange to me.
By the way I am new to this restoration stuff and there is a lot off stuff I would have done differently
Re: 1976 350 Road
Postby graeme » Wed Jul 27, 2022 8:10 am
I had a Norton Commando with Amals, with the choke lever tensioned, the choke was closed.
Reversed to Dellorto.
Re: 1976 350 Road
Postby George » Wed Jul 27, 2022 9:01 am
Bike looking good. Common mistake with Amal choke. Not all Dellorto chokes reversed. Friend spent a month trying to get Elite running, no power and running rich then realised choke on when lever NOT under tension. Instant cure.
A.I.M
Re: 1976 350 Road
Postby A.I.M » Wed Jul 27, 2022 6:37 pm
I can add that I recently checked with Burlen about choke operation on my Amal 627, as I was similarly confused.
The advice was: The choke slide is DOWN with a relaxed cable to operate the choke and UP under tension when it is off.
My recollection of operating the bike (admittedly 40+ years ago) was the opposite, but I'm clearly having memory trouble! However it does seem counter-intuitive engineering to have to tension the choke cable for normal operation, rather than for the temporary operation of the choke.
Al
Re: 1976 350 Road
Postby blethermaskite » Wed Jul 27, 2022 8:31 pm
All Amal airflow obstruction chokes have been operated as.... lever closed choke on/lever open (under tension) choke off.
Re: 1976 350 Road
Postby themoudie » Wed Jul 27, 2022 10:57 pm
As George says, applies to AMAL MKII type.
MKII carb mounted choke lever raised to apply choke, depressed to remove choke effect, by raising choke plunger from obstructing the drilling.
Users browsing this forum: Google [Bot] and 94 guests
