Bottom bevel bearings.
Buster
Re: Bottom bevel bearings.
Postby Buster » Fri May 17, 2019 5:46 pm
If the cases are heated and the bearings are kept in the freezer overnight they should drop in.
jbcollier
Postby jbcollier » Sat May 18, 2019 4:42 am
Re: crank shimming
You can't shim the crank "tight". If you do, it just pushes the crank out of alignment. You just shim to take out the play, that's it.
