Lets push on, see where it goes.
Harvey.
____ Have you yet noticed that I've edited your posted-pic.diagram (hopefully as you had wished) ? _ (And I wonder where you came-up with that from ?)
__ And could you please give your reason/explanation for having posted it ? - (As there are things I'd then like to point-out about it, as well.)
I think you missed this bit.
“As for the “HT.sparking-juice”, that High voltage of about 12kv from the secondary, only exists across the resistance of the plug gap. The rest of the circuit only flows battery voltage at about 2amps.”.
____ No, I didn't miss that, (in fact that's ONE-thing I was referring-to [at the bottom of my earlier-post] when I stated: (cuz I'm led to think-of more than one concept that your chosen-wording may be meaning to convey)),, and had actually read it more than once, but just wasn't sure of exactly how it was meant to be understood (cuz it seems partially incorrect).
So where have you always been whenever electrical-stuff has been discussed in the past ?
____ Of-course that's quite true, as there will then be no high-VOLTAGE,, however the HT.current (of the HT.secondary) will still remain under high-TENSION ! _ ('Tension' is electrical-drive/pressure, [before it ever becomes measurable as 'voltage'].) ...
__ Some believe that 'voltage' is the intended term for representing "electrical-drive/pressure", but actually that's what 'tension' really is. _ And 'voltage' is-to 'tension', as 'temperature' is-to 'Fahrenheit' (or Celsius).
____ All quite true, however the primary-voltage in the 160-system is not so much as "250V" ! _ Rather, it's only up-to as much as 70-volts (BEFORE being subjected to the operating-circuit, when it's then bled-down to much less).
____ First thing I need to address is that I had SCREWED-UP my last (underlined) sentence-statement & stated that rather BASS-ACKWARDS ! ... As it should've been worded: 'voltage' is-to 'tension' (in much the same way) as 'Celsius' is-to 'temperature'. .Harvey wrote:DCT-Bob wrote:____ Of-course that's quite true, as there will then be no high-VOLTAGE,, however the HT.current (of the HT.secondary) will still remain under high-TENSION ! _ ('Tension' is electrical-drive/pressure, [before it ever becomes measurable as 'voltage'].) ...
Word, words, wording. Terminology can change the meaning. Voltage is the measurement of potential “tension”?
I prefer to use the term Energy, described in our use, as Power. The generator produces Energy, we measure it as Power, that is the product of Volts X Amps. So a power of 200 watts from the generator, can be taken as, 20V at 10 amps, or 2V at 100 amps, or any other combination. It depends on the resistance of the circuit that is using that power.
" Voltage is the measurement of potential “tension”? "
____ Was that question spawned by my screwed-up misstatement ?
__ (Anyhow, the word 'potential' has splintered-off from it's original-meaning [which everyone is familiar with], to also be used as an electrical-term [standing on it's own] as well.)
__
____ Anyhow,, you've coined the phrase-term "potential tension' ... I suppose that could be used within a description that's meaning to tell of what's possibly going to become available within a HT.coil that could become electrically-charged,, but otherwise, I'm not much aware of such term-phrasing as that being commonly used.
__ But yes, 'voltage' (in one of it's aspects), is a possible measurement of 'tension'. _ And tension is that which exists before it's bled-into a circuit where it can then be valued as voltage, (it's particular voltage-amount dependent on the circuit).
To perhaps more-so address the posted-question,, 'voltage' is a measurable version of tension, once tension has gotten a chance to bleed through a circuit, (and voltage-itself doesn't exist until then, except as potential-voltage -[which is often merely referred-to as 'potential'] ).
__ " That diag, was shameless stolen from Phil Irvin’s Motor Cycle Engineering. It is the Lucas Energy Transfer System used on the Triumphs. Shows the circuit plainly. "
Thanks for that.
__ I wonder if it's ACTUALLY correct ? _ As it doesn't show the HT.coil connected-up as a standard auto-transformer arrangement.
I'll soon alter & post that diagram's scheme, (soon-as I get to doing so),
so-as to then indicate exactly what I mean about it.
____ Really didn't yet decide for-sure that any part is actually "incorrect", cuz I'm not sure of exactly what circuit only flows "about 2amps". _ It [i]seems]/i] that you may-NOT be referring to the current that flows through the primary from the battery, (of which 2-amps would be about what's expected). _ The possible-issue much depends on exactly which circuit you actually mean, when you stated: "The rest of the circuit"
____ So are you then indirectly indicating that his AC.reading of just "9 volts" is possibly why he's not getting any 'spark' ?
__ Cuz I've measured good working systems, and even at max.revs, it's difficult to attain voltage-readings near 100-volts (on good v.meters).
" If you want I can describe its action. "
____ Of-course you may do that as you wish, but you may care to wait until after I've pointed-out that which I think may be wrong about it.
UPDATE - Now that I've finally posted an altered-version of that diagram, (which indicates the change in the depicted ground-circuit),, it would certainly be of interest to have you go-ahead & "describe it's action", on the original (and also on my altered-version [if you see any noteworthy difference] ).
" With Energy Transfer, the two windings have to be electrically separate, as we can’t have the secondary current flowing through the primary circuit. It would retard the rise of the secondary voltage. "Harvey wrote:That diag, was shameless stolen from Phil Irvin’s Motor Cycle Engineering.
Shows the circuit plainly.DCT-Bob wrote:__ I wonder if it's ACTUALLY correct ? _ As it doesn't show the HT.coil connected-up as a standard auto-transformer arrangement.
" I was talking about the secondary circuit flow. If the HT power is 12k volts at 0.003 amps at the plug gap, that same energy is still flowing but at a lower voltage and a higher amperage. So the rest of the secondary circuit will reflect the energy that the primary transferred to it. "____ Really didn't yet decide for-sure that any part is actually "incorrect", cuz I'm not sure of exactly what circuit only flows "about 2amps". _ It seems that you may-NOT be referring to the current that flows through the primary from the battery, (of which 2-amps would be about what's expected). _ The possible-issue much depends on exactly which circuit you actually mean, when you stated: "The rest of the circuit"
" I don’t think you are going to read these peak voltages on any meter. It needs a scope to see the peak of the waveform. Just turning it over has all the voltage shorted out by the closed points, except for the one wave, but when the points open the voltage will spike to the high voltage. "__ Cuz I've measured good working systems, and even at max.revs, it's difficult to attain voltage-readings near 100-volts (on good v.meters).
" The circuit that I posted is the way it is connected. If we assume that this is a negative grounded system, the generating coils/coil are producing power, to flowing an AC current through the closed points, so that the circuit has virtually no resistance. This means that there will be a high current flow at a very low voltage.Now that I've finally posted an altered-version of that diagram,
it would certainly be of interest to have you go-ahead & "describe it's action", on the original (and also on my altered-version).
____ I-myself am not really sure about that* Harvey, as I do-not KNOW how the winding-relationship actually is, (between the primary & secondary). _ But assuming that you're totally correct on that, then that would certainly be a good-reason for the varied existence of the Green-labeled HT.coil, (in place of a standard auto-transformer type of HT.coil) ! _ (Sort-of wonder why you hadn't mentioned that potentially important detail within your earlier posting !?)
(* I'm not quick to buy-into that reasoning because, it's been found that ign.sparks still occur (seemingly equally), regardless of which primary-circuit input-terminal is chosen to be the one that's grounded.)
(I'll post pix related to this.)
____ Well Harvey, you've now CONFIRMED that you really indeed had meant exactly what I thought your original-wording might be meaning to state ! _ It's just that I had figured that I must be wrong to interpret it THAT-way, because that assumption of yours is indeed incorrect. ...
__ I wouldn't argue-against that point of yours, IF the plug-gap (along-with the rest of the secondary's resistive-load) was the same as-if the gap was closed to zer0-clearance,, BUT however, the spark-gap is by-far the highest resistive-load within the secondary-circuit, and-so THAT sets the absolute LIMIT for maximum current-flow throughout the secondary's entire circuit ! _ (I'd expect anyone with your extensive knowledge to already realize such ! _ [Which is why I had doubted my interpretation of your stated-claim.] )
So-then if the current across the plug-gap is just ".003 amps", then that amount of current-flow REMAINS the very-same, throughout the entire secondary-circuit !
(Certainly it ought-to be realized that if current-flow quantity-values could possibly change whilst flowing anywhere within such a single closed-circuit, then electronics would have to work as-if 'magic', [cuz resistor-values would then NOT have their predictable effects on current-flow rates !].)
__ (However I must admit that WHEN circuits are involved with storage-batteries, seemingly magical-effects do at-times seem to occur.)
__ Now that it's realized you were believing that such changes in current-flow capacity-rates were occurring in the secondary-circuit, I can now better understand why you haven't realized exactly where that rather very-thin current-flow actually goes-to (after passing-through the plug-gap), in order to completely-satisfy the secondary's electrical-demand for a completed circuit-pathway.
NOW do you think you realize how that's ACTUALLY done, (rather than through the battery) ? _ Or are you still waiting for me to go-ahead & explain it ?
____ OHH!, I see what you had actually meant now...
I had thought that you were referring-to the 'RMS.voltage' inputted into the ign.circuit (from the alt.stator), but NOW I realize that you had been actually referring-to the 'flywheel-effect' spiked-voltage (that's caused by the collapsing flux-field within the stator-coil), in-order to obtain such high voltages as "375v".
I was aware that such kicked-up spiked-voltages actually existed but, I didn't know that they had a limit so low as you've stated.
=Ducatikid. I get 3.6 ohms between the 2 separate side posts. 11.12 ohms thru center (inside) post and to each side posts. Both readings are the same. There is no resistence or continuity from the center post to the can
Also, the test numbers on the HT coil was for the original Ducati Elettrotechnica coil. The same testings on the new 6V HT coil were double those numbers.
____ As I've already covered at-least twice before within this thread, altering the polarity of the wiring connected to the HT.coil makes no notable difference in the intensity of the spark. _ (As I've already tried that reverse wiring experiment back in the late-60s.)Ducatikid wrote:Ahhhh, it seems I need to do some experimenting with my HT coil and the wiring
DCT-Bob wrote:however, the spark-gap is by-far the highest resistive-load within the secondary-circuit, and-so THAT sets the absolute LIMIT for maximum current-flow throughout the secondary's entire circuit !
" But in this circuit we are using an amount of generated energy of no fixed voltage,Harvey wrote:Yes that would be exactly right Bob as long as the circuit was powered by a source with a fixed voltage, like a 12V battery. We can then use Ohms law to work out any of the voltage, current, or resistances, and the current flowing in the circuit would be same right through the circuit.
____ I find this to be of certain-interest but, it will have to be further discussed, later.But in this circuit we are using an amount of generated energy of no fixed voltage, just an amount of power, about 40 Watts that we can measure as volts X amps. This power will flow till exhausted. The resistance of the plug gap will set the voltage, which we measure at 12,000 volts with a current of 0.003 amps. Once the gap resistance is passed, there is still the same power flowing through the rest of the circuit, (less some % lost to heat and sound) but there is now a low resistance, so low voltage, say about 12 V so 30W / 12V = 2.58 Amps.
This is the same transformation of energy that takes place when the points open, and the power from the generating coil changes from low volts high amps, to low amps high voltage.
DCT-Bob wrote:__ I can now better understand why you haven't realized exactly where that rather very-thin current-flow actually goes-to (after passing-through the plug-gap), in order to completely-satisfy the secondary's electrical-demand for a completed circuit-pathway.
" I see what you are saying here, but the sudden rise in voltage is not due to the stators field collapsing, as it is still generating power. It is the high Impendence / resistance, of the primary circuit’s Inductance Reactance, which is suddenly introduced into the circuit, that causes the voltage rise. "DCT-Bob wrote:“the 'flywheel-effect' spiked-voltage (that's caused by the collapsing flux-field within the stator-coil,”
" then the secondary has no separate ground, and is grounded at the same side terminal, as the primary is connected to. This then means the coil has to be connected with this terminal to ground, and the other terminal connected to the power source, "Having look at this system in detail, I think we can go back to Ducatikid’s problem.
