DESMO Discussions (continued, here) Thread
Re: DESMO Discussions (continued, here) Thread
Postby machten » Thu Mar 07, 2013 2:59 pm
Appreciate, you're not finished your post, but it's bed time here, so I'll inject a clarification...
__ Anyhow Kev, it seems that you must've SKIMMED-through those posts of mine
That might happen in areas that don't particlularly interest me at the time (even so, I always do my best to mentally store away a reference in my memory anyway). This does interest me, so I read it in some detail and thought about it. I'll be honest...the final sentence was deliberately intended as an equally thought provactive challenge as your "lose the desmo closer lobes" suggestion. The evidence that I have thought about things is the final part of this sentence:
If taking the mechanical closer out for anything other other than inital change of direction momentum is a good idea...
I think I understand the value of the inital closing launch (change of direction of momentum), but I think it's good that you have explained your thinking for everyone. And I think it is relatively simple physics to calculate the length of the current stock cam closing lobe actually required to achive the objective of launching to the seat without the benefit of the full closing lobe. This effectively deals with valve float (which I am thinking is the largest issue). I'm thinking that it doesn't deal with valve bounce - particularly with a light spring or no spring. So I guess I'm wondering if "bounce" is an issue (at some high RPM!).
The "was Dr T wrong" question was because as a race oriented engineer, he must have seen some benefit in those heavy closing lobes. The system is still used to this day, and based on your theory I'm not getting why.
Any NEED for the EXTENDED Closing-lobe Track-face ?
Postby DewCatTea-Bob » Thu Mar 07, 2013 4:20 pm
" the final sentence was deliberately intended as an equally thought provactive challenge as your "lose the desmo closer lobes" suggestion. "
____ That's why I figured that you must've skimmed-through, cuz I never meant to insinuate the COMPLETE elimination of the entire closing-lobe.
I guess it now seems that I was mistaken to suspect (from your chosen wording) that you had actually thought that THAT's what I had meant.
" The evidence that I have thought about things is the final part of this sentence
" ____ Ahh, yes,, I now clearly/correctly understand what meaning that wording was actually meant to convey.
" And I think it is relatively simple physics to calculate the length of the current stock cam closing lobe actually required to achive the objective of launching to the seat without the benefit of the full closing lobe. "
____ For the purpose of just merely launching the valve back towards it's seat, probably only about half of it's closing-RAMP height would be required for THAT (rather simplified) task.
" This effectively deals with valve float (which I am thinking is the largest issue). "
____ Surely indeed.
" I'm thinking that it doesn't deal with valve bounce - particularly with a light spring or no spring. "
____ You're certainly indeed a good/deep-thinker ! ... As valve-seat bouncing was a consideration which I as-well thought could possibly be an issue for the closing-lobe to help deal-with as well.
But if any such bouncing actually could occur, it sure wouldn't be more than once per valve-seating occurrence, so the need for the overly-EXTENDED length of the lobe's track-face is STILL without any useful function !
__ I actually had expected that somebody might be bright enough to bring-up this particular concern about possible valve-bouncing off-from the valve-seat,, and-so if you closely check-out the picture that I had previously posted (with the red-line indicating the section of the lobe to be considered as useless), you can then clearly see that I not-only intended retainment of all of it's entire closing-ramp, but also a minimal section of the lobe's fully-closed track-face as well, (for just in-case there possibly IS a valve-bounce issue which really needs to be kept minimized).
" So I guess I'm wondering if "bounce" is an issue (at some high RPM!). "
____ It could possibly exist I suppose,, but if so, it would be of very-little action with the internal cylinder pressures opposed against it.
The "was Dr T wrong" question was because as a race oriented engineer, he must have seen some benefit in those heavy closing lobes. The system is still used to this day, and based on your theory I'm not getting why. "
____ Well that makes two of us then.
__ It would be extra interesting if the question could be posed to him !
However I much suspect that the total-answer to that is probably merely to fully maximize-out the function-concept, (as the perfectionist-attitude which drives many of us, is apt to dictate),, pretty-much the same as would be bothering to further-extend pin-striping detail-work to the UNDERside of newly-painted fenders.
Postby graeme » Thu Mar 07, 2013 10:05 pm
I've found these diamond laps work well and are easy to hold and guide, should anyone want to play with their cam closing lobes. (about $12 each)
Harvey
Postby Harvey » Thu Mar 07, 2013 10:17 pm
I was always getting into trouble, for using my best girls diamond nail files, to rip a shim down close, then finish off with wet/dry on a sheet of glass.
Harvey.
Postby machten » Sat Mar 09, 2013 4:27 am
The other thing that comes to mind after some more consideration, is that the exhaust valve needs be held closed "enough" during the induction stroke when there is negative pressure in the cylinder, so either the light spring needs to be sufficiently strong to resist, or in the case of "no spring", you probably do need enough of the closer lobe to hold the exhaust valve closed for "enough" of the induction cycle. Are you thinking Bob that the portion of the closer lobe you've nominated as remaining is sufficient to do that?
I'm thinking if one was to implement Bob's closing lobe theory (and wouldn't it be fun to test it out!) there could be good reason to consider having different (smaller than stock) closer lobe durations for Inlet and Exhaust lobes.
...and at this point I publically declare I'm getting beyond my depth...
Postby graeme » Sat Mar 09, 2013 5:19 am
Hmmm,,,,
I find it hard to imagine any gain (considering the amount of work involved to remove a large piece of lobe) as opposed to just lapping the closing lobes and forever more being done with worrying about any future binding issues?
Interesting none the less.
The V2 cams with the phasing issue, did they have a V2 part number stamped in them?
Postby machten » Sat Mar 09, 2013 5:55 am
From my own personal perspective, I agree, Graeme. I was just wondering more around why they were produced that way in the first place rather than the cost/benefits of modifying them from what they are. I haven't even made the effort to do the stoning work you have...I just run the closers a bit loose, as I find my Duke quiver presents me with more than enough "must do" work to prevent me getting the time to get to the "nice to do" work. :D
Given their relative mass and distribution from the centre of rotation of the camshaft, you'd think they have some small effect like a mini flywheel...and if so there are pros and cons to reducing that mass - so yes, I also wonder how much of a benefit it would be to reduce the mass of the lobes. There must be some benefit, or they wouldn't have drilled the holes in the lobes.
In any case, whilst I am very unlikely to ever go anywhere with this, I'm almost sorry to say, I've enjoyed thinking about it! :geek:
regards,
Postby graeme » Sat Mar 09, 2013 8:16 am
"In any case, whilst I am very unlikely to ever go anywhere with this, I'm almost sorry to say, I've enjoyed thinking about it!"
Yes, it keeps the old sludgy grey matter lubricated (old in my case!)
Seeing how Pantah onwards don't have this binding issue, and Dr T designed (penned) the Pantah engine in the mid '70's and from then on there was no need to worry about this strange fault, I guess it wasn't meant to be that way originally.
But there were some that were out a few degrees, (to this day) which could be just misplaced rocker pins or such.
And manufacturing machines became more precise.
Has anyone used the red/white Desmo cam?
Does it have a binding issue?
As far as I'm aware it's of the same vintage.
Postby DewCatTea-Bob » Sat Mar 09, 2013 9:37 am
machten wrote:The other thing that comes to mind after some more consideration,
____ I actually appreciate that you (for one) seemingly comprehend & understand the matter which I've pointed-out in this thread, and have also bothered to further think-out any possible flaws in my conception of it.
" is that the exhaust valve needs be held closed "enough" during the induction stroke when there is negative pressure in the cylinder, so either the light spring needs to be sufficiently strong to resist, or in the case of "no spring", you probably do need enough of the closer lobe to hold the exhaust valve closed for "enough" of the induction cycle. "
____ This possible issue consideration is even better conceived than your last, and it's another issue-point which I've already-before considered & dismissed. ...
__ When I first realized that there seemed to be no actual need for the closing-lobe's track-face once the rocker-arm's follower had tracked past it's closing-ramp section, that was with the consideration that Ducati still retained the service of valve-spring type springs (probably only because that type of closure-spring was already tried-&-true & proven as reliable for mass-production).
However for starting-purposes, the weaker rocker-spring has also proven itself sufficient to keep the valve seated even after the perfectly-set closing-clearance (between the closing-lobe's upper-most track-face & it's follower) has loosened-up past it's intended zer0-setting. _ So-thus that (extended)- section of the closing-lobe is then no-loner able to provide sealing-assistance anyhow, and-thus the rocker-spring is then certainly left without that particular assistance with the valve sealing-job. _ Yet even so, the kick-starting process doesn't suffer any.
__ That point made, now onto the next...
" Are you thinking Bob that the portion of the closer lobe you've nominated as remaining is sufficient to do that? "
____ No, not entirely,, as that (rather skimpy) remaining section probably doesn't continue-on to cover the duration-point between 90-degrees ATDC & BDC (during the intake-stroke).
__ However, under racing conditions (when an engine is push-started, rather than kicked-over), even a rocker-spring could be dispensed-with as unneeded.
And that's because there's still ANOTHER factor which tends to keep the exhaust-valve closed ! ...
__ At higher engine-revs (above kick-starting RPM), especially with wilder-cams (like the DESMO-cams), the 'momentum' of air-flow is not to be so much assumed as being merely a relatively weak force, (as it's that particular force alone, which is depended upon to allow a wild-cam to better fill the cylinder at higher RPMs !).
That air-flow momentum-force is another factor which helps to close (and hold closed) the ex.valve...
So when the piston's intake-stroke is creating negative-pressure within the cylinder (of a RUNNING engine), the intake-charge was already waiting (behind the intake-valve) in an overly-positive state of pressure, so-thus THAT volume of air really WANTS to fill the cylinder, (and helps to push the ex.valve shut),, whilst the momentum of the mass of the exhaust-gasses,
(which had just been pushed-out and thus isn't interested in stopping & going BACKward into the cylinder [especially when there's another opening with air that's more than glad to do so instead]),
creates a vacuum which strongly tends to suck the ex.valve closed (just as a reed-valve would certainly do), and until the main mass of that expelling ex.gas has escaped the exhaust-plumbing, it's sucking-force only tends to pull the ex.valve shut !
So (except at the lowest engine-speeds when there's relatively little air-momentum), it ought to be understood that the cylinder's desire to become filled is seconded-ordered with respect to the ex.gases wishing to continue on their way out (through the ex.pipe). - (If there was no exhaust-pipe/plumbing, THEN the sucking-effect would instantly disappear,, and probably THEN the ex.valve WOULD indeed be left inclined to become [temporarily] pulled back-open, just-as you had speculated as possible).
But we do know that (at higher engine-speeds) the momentum of the ex.gas must be strong enough to pull a (normally free-sliding) ex.valve shut, cuz that's the very-same force which causes 'overlap' to be as effective as it's known to be !
" I'm thinking if one was to implement Bob's closing lobe theory
there could be good reason to consider having different (smaller than stock) closer lobe durations for Inlet and Exhaust lobes. "
____ This post of yours has now lead me to a new thought, (which I need to further think-out, to become absolutely sure of),, as it seems that a performance-gain might possibly also arise from that suggestion.
__ UPDATE - The new-thought which Kev's posted-wording (inadvertently) inspired, is concerning what BENEFICIAL, (as opposed to merely neutral), side-effect could possibly result from such proposed running without normally restricted-control of the valves...
__ Well we know that the purpose of valve-springs, and also that of the closing-lobes, is to prevent 'valve-float' ... but what-if not only the return-springs were removed, but also that greater-bulk of the closing-lobes as well ? - With just the closing-ramp left remaining intact !?
Normally when the valve has reached the maximum lift-height of the opening cam-lobe, the springs & closing-lobe's track-face then hold-down & restrict the valve from further advancing to any higher-point than that dictated by the opening-lobe's designed-height ! _ So what if that (normally)- set restriction was completely removed ?
Well then as the revs climb higher, such a less restricted valve would then likewise be launched harder and thusly become more apt to open-up & outward to an even higher-point. - (And of-course we're aware that when the valve-head is raised further out of the way, increased air-flow is then the result.)
The ADDITIONAL available valve-lift would sort of work like a reed-valve - becoming more aptly to increase as RPMs built-up higher,, and-so this would be the beneficial-effect of valve-float, (without it's negative-effect, since the closing-ramp would still prevent THAT aspect).
Of-course the available increased lift wouldn't be much more than just 2mm, since the closing-cam track-face is minimumly raised above the shaft, when near the point of max.valve-lift.
And rocker-springs would need to be required so as to make-sure a gap doesn't develop which could possibly allow the C-clip retainers to escape. -
(So THAT's the only possible reasoning for the original inclusion of the extended closing-lobe track-face - [for in the event that no closure-springs are employed], that THEN there's SOMETHING-else to make-sure those valve-keepers can't develop any chance of squeezing-out from their intended location.)
" ...and at this point I publically declare I'm getting beyond my depth... "
____ But you've been doing so well, and it seems that you're the only one who has wished to come-out & play.
" Given their relative mass and distribution from the centre of rotation of the camshaft, you'd think they have some small effect like a mini flywheel. "
____ Yes there's THAT effect, (neither good or bad),, but that's certainly also a source of some amount of added vibration (that's no-doubt considerably stronger than that of a cell-phone vibe.ringer-function).
" I also wonder how much of a benefit it would be to reduce the mass of the lobes. There must be some benefit, or they wouldn't have drilled the holes in the lobes. "
____ Probably done merely to reduce the off-center weight that's being flung-around inside there.
" I'm almost sorry to say, I've enjoyed thinking about it! "
____ Yep, as it's fairly good brain-food for building-up it's muscle-lines.
Postby graeme » Sat Mar 09, 2013 10:29 pm
Think of the combined weight of valve, opening and closing rocker, shims and collets flying up and down in an unrestrained manner, even only 2mm at revs. How much loose hammering would occur to all this gear?
Collets and shims and the valve would cop a hiding?
If springs were not fitted.
It would need to be a strong spring to stop the clatter, (inertia), then what's the point in desmodromics?
Users browsing this forum: No registered users and 71 guests
