veloduke wrote:I believe selenium diodes have more forward voltage drop than silicon diodes, hence the lower efficiency.
I stand corrected.
I was thinking of germanium diodes.
George wrote: Searching the forum yesterday I found a wiring diagram in the Italian manual that was more clear than my copy <snip>
George wrote:<snip>
As I have it wired up, the following applies with engine stopped:
Ignition on, Headlight switch off, brake light and horn operates ... <snip>
Jon Pegler wrote:The Spanish wiring diagram shows a red, a white and a yellow wire from the alternator.
George wrote:Looking at excellent wiring diagram supplied by Jon, it would seem that white wire is connected part way along top coil and my reasoning is that this should have a lower resistance than yellow to red. My readings are: Yellow 1 to red = 0.5 ohms. Yellow 2 to red = 0.7 ohms. If my theory is correct, this would indicate that yellow 1 is the white connection.
Users browsing this forum: No registered users and 105 guests
