Compression Release
frankfast
Re: Compression Release
Postby frankfast » Tue Nov 02, 2021 9:57 am
I think the Sebring had a compression release with screw type adjusters on their rocker arms. Maybe someone can confirm.
Postby Ventodue » Tue Nov 02, 2021 12:12 pm
Dunno about the Sebring, Frank, but my Vento has screw type adjusters ... and a decompressor (as you know ;) )
frankfast
Postby frankfast » Tue Nov 02, 2021 8:49 pm
Thanks Jordan and Vevtodue. Now I have to go searching for a spring and washers that will work.
frankfast
Postby frankfast » Sat Nov 13, 2021 8:05 pm
Jordan - The first illustration that you posted may be a bit misleading. It seems to show that the washer and circlip is outside the valve cover. I've assembled those pieces inside the valve cover so that the pin and spring cannot be removed without removing the circlip. Correct me if I'm wrong. Also, as I've mentioned before, the rockers are not the standard shim type but rather screw type and therefore the profile is different. I've had to shorten the pin for it to work so that the valve cover will fit to the gasket. - Frank
Postby Jordan » Sat Nov 13, 2021 9:13 pm
You mean the exploded drawing?
I can't remember the order of assembly, but you've figured it out.
Well done for discovering the needed modification to suit your adjustable rocker.
ducridersantafe
Postby ducridersantafe » Sat Oct 29, 2022 5:34 pm
Hi all, I'm picking up this thread again, (sorry) I have a 450 springer engine with a valve lifter installed and I'm having a hard time wrapping my head around this. If what Jordan is saying is correct, pulling the lever at the bar end (in this case, it's a choke lever type thing) the steel cable pulls back and the valve lifter lever drops down onto the plunger, releasing pressure in the combustion chamber? So the sheathing is what's pushing down on the lifter mechanism? Thanks, Terry
Dave354
Postby Dave354 » Sat Oct 29, 2022 7:19 pm
Exactly, or you could say the outer sheath is the rigid brace against which the inner Bowden cable runs through… As you pull the handlebar lever the cable pulls the decompressor lever down which in turn pushes the exhaust valve open against its spring.
I’ve left mine off my 350 as I’ve put a soft compression on
Dave
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Postby themoudie » Sat Oct 29, 2022 10:28 pm
Aye Terry,
Yes.
frankfast
Postby frankfast » Sun Oct 30, 2022 10:45 am
Dave354 wrote:Exactly, or you could say the outer sheath is the rigid brace against which the inner Bowden cable runs through… As you pull the handlebar lever the cable pulls the decompressor lever down which in turn pushes the exhaust valve open against its spring.
Dave
What does that mean? put a soft compression on?
Postby Duccout » Sun Oct 30, 2022 11:41 am
Piston, I guess?????
Users browsing this forum: No registered users and 151 guests
