Any resto's going this winter?
Re: Any resto's going this winter?
Postby Eldert » Sat Dec 05, 2009 12:45 pm
anyway : back to restorations
this is the project in am working on right now
it is a 450 bored and stroked ( 90 X 78 )taken out to 496 cc .i put a springer head on with reangled oversize valves
74 degrees combined valve angle and 44 mm and 38 mm valves
i had new inputshafts made up that wont break and put on straight cut primary gears with a differend ratio
to speed up the gearbox so there is less load on the gears
i made the rear swing arm 2 inches longer and i put Scrambler bottom sliders on the front fork and laced
a Grimeca 180 mm 4 shoe brake to the 21 inch rim
put in a alternator instead of the flywheel magneto ignition and converted to 12 volts
electronic ignition is Boyer and no battery is fitted but a Boyer Powerbox to rectify and store some energie
i am working on a wiring loom right now and then she is ready to fire up
Regards Eldert
Postby DewCatTea-Bob » Sat Dec 05, 2009 2:13 pm
____ Very,very nice, and much of interest here, Eldert!!
__ How did you get the extra 3mm of stroke, install a larger crank-pin in a relocated crank-throw, or simply use a 1.5mm offset-pin?
__ The stock valve-angle is 80-degrees... How about posting some pictures of your much modified 450-springer-head?
__ The stock primary-ratio is 1:2.11 (57/27t), what did you up it to, 1:1.8 ?
__ I hope you don't use a type of full-wave rectifier (on the entire output of a standard wide-case alternator), that wastes excess juice to ground!?
____ Too bad that Ducati never did these mods, as you have, Eldert !
DUKE-Cheers!!
Postby Eldert » Sun Dec 06, 2009 5:47 am
here a picture of the reshaped combustionchamber . i put a small 10 mm sparkplug as high as possible in the head
i stroked the crank by using a straight 34 mm bigendpin ( from a Yamaha ) in the relocated hole
Postby Eldert » Sun Dec 06, 2009 6:18 am
the new primairy gears are 53 / 29 so the ratio is 1 to 1.827
and the new inputshaft witn new 2nd and 3rd gears . changed 2nd gear from Z =22 to Z =21
so we could put 3 dogs on a whole tooth
the original inputshaft can break at the circlipgroove for 2nd gear when you tweak the engine
Postby DewCatTea-Bob » Sun Dec 06, 2009 7:24 pm
" here a picture of the reshaped combustionchamber . i put a small 10 mm sparkplug as high as possible in the head
and the new inputshaft witn new 2nd and 3rd gears . changed 2nd gear from Z =22 to Z =21 so we could put 3 dogs on a whole tooth "
____I'M VERY IMPRESSED Eldert! _ (And that doesn't happen too easy!)
As I doubt that there's any other individual (currently) in the world, who has come close to matching the great extent of your extreme modifications (to their DUCATI-single), as you have!
So I sure vote for you as TOP-Modifier of DUCATI-single projects! _ Cuz I now am quite sure that if there were to be a 'WORLD-WIDE Show' for all DUKE-projects,, that you, Eldert, would surely take the Top-TROPHY as KING of the show!
Top-Cheers for Eldert!
PS. Sorry if I have gone over-the-top here, but, I'm THAT IMPRESSED!!
Postby Eldert » Fri Jan 01, 2010 10:08 am
DUKE-Cheers!!
-Bob[/quote]
Hi Bob
i ditched the original full wave center tapped rectifier design and went for a full wave bridge type rectifier and did
not use the center tap ( the red wire ) only the 2 yellow wires are used with this setup
Postby DewCatTea-Bob » Fri Jan 01, 2010 12:42 pm
" i ditched the original full wave center tapped rectifier design "
____ Eldert, your two diagrams are both correct representations of your 'before & after', (although the diagram which is supposed to represent the stock set-up, shows it's 2 diodes facing backward!).
__ However the stock rectifier-unit is not "full wave",, it's more like 'dual half-wave', (as 4 diodes are required for full-wave rectification, and the original-unit has only two power-diodes)!
"and went for a full wave bridge type rectifier and did
not use the center tap ( the red wire ) only the 2 yellow wires are used with this setup "
____ Right, that's the easiest (& cheapest) way to convert to a 12-volt system!
The downside to not making any use at all of the RED-wire-lead, is that if you run at high-RPMs with lights off, your voltage-regulator will be overworked, and many such regulators simply dump excess power-juice to ground, thus robbing power from your rear-wheel, while also over-heating the alternator, & reducing fuel-economy!
__ That's why I had mentioned before that I hope you don't use such a rect.reg-unit on the entire output -(between the two yellow-wires) of that "70-watt" alternator!
____ I know of several (more complicated) wiring-methods for taking full advantage of that alternator's capability, without as much waste.
I may get to posting details about that some time.
DUKE-Cheers,
DesmoDog
Postby DesmoDog » Fri Jan 01, 2010 6:24 pm
DewCatTea-Bob wrote:____ I know of several (more complicated) wiring-methods for taking full advantage of that alternator's capability, without as much waste.
Please do, I'm nearing this phase on my projects and am confusing myself with the different options..
Postby DewCatTea-Bob » Fri Jan 01, 2010 10:06 pm
" I'm nearing this phase on my projects and am confusing myself with the different options.. "
____ Well Craig, it would take me a real long time to post complete details on each of the methods I know of for wide-case models! _ So I would need more details on what you have going and what you wish to accomplish.
Do you have your stator removed? _ (The best modified-system requires adding a 4th wire-lead. - [Although it's advantage is not worth the work involved, just to add a 4th-wire].)
Would you care to install an AMM-meter -(like Brit-bikes have employed), on your project? _ If not, it would be convenient to use a light-switch (which includes a dual-switch) like Jap-bikes use.
Do you have such a switch, or would you be willing to obtain one for your project?
Otherwise, if you use a manual-switch of some sort -(toggle?), then it would be up to you to guess when your system can use the extra-power that's available from the wide-case alternator. _ (As it really doesn't make good sense to require your engine to force the alternator to produce more power-juice than your electrical-system can make good use of [at any given time]! - As Eldert's full-wave scheme would definitely do whenever the lights are not on!)
__ If you have any question that's directly related to anything I have written in this thread, then please post it here. _ Otherwise save any other questions related to this particular subject for when I've started a new thread specifically for modifying the WideCase charging-system.
Tillater,
DesmoDog
Postby DesmoDog » Sat Jan 02, 2010 5:01 am
Oops... both my projects are narrowcases... a 160 and a 350.
Users browsing this forum: No registered users and 71 guests
