[quote= cooperplace ...
" BUT it also occasionally gives random much weaker yellow sparks at other parts of the engine cycle. "
____ That's most-likely from when the ign.points close.
" I think this is the cause of the problem. "
____ If you find that the odd-spark is-not always occurring when the points close, then it's cause is probably related to a loose electrical connection somewhere.
" Could an internal coil fault cause this perhaps? "
____ Yes, if it just happens to have a somewhat loose internal connection-interruption, but I'd expect such to be more prevalent than you seem to experience,, and besides, such a possibility would be EXTREMELY rare.
" I would like to try it with another coil. The coil on it is completely anonymous, "
____ Then why-not try-out the original Ducati red-label ign.coil ?
__ If you find that coil becomes too warm after 10-minutes of operation, (and it works better for you),, then you could connect an ign.ballast-resistor in series with it to cut current-flow through the circuit after the resistor heats-up.
The use of such ign.resistors is a trick used to improve cold-starting ! _ It allows for a hotter spark (when the engine hasn't been recently running and the resistor is thusly cold), and yet protects the ign.coil from possible overheating.
____ Please let us know the results of any coil swap you try-out. _ And-also if you also try it along-with your Dyna-unit.
250 Monza: vicious kickback
Re: 250 Monza: vicious kickback
cooperplace
Hi Bob,
Thanks for the as usual excellent advice. How would a universal 12V coil such as this Ebay cheapie, made by Emgo, work:
http://www.ebay.com.au/itm/381017447177 ... 1438.l2649
thanks
Peter
thanks
Peter
be nice, I'm not very bright.
cooperplace
some googling shows that this coil is 1.5 ohm which will pull too much current thru the points, I think I need a 3-4 ohm coil.
" How would a universal 12V coil
work: "
____ Sorry Peter,, I don't know for sure, but probably about as well as most any other.
__ The price of that coil isn't what I'd say is a 'cheapy',, and when ya also include the seller's shipping-charge, the total-cost is then quite unreasonable !
Don't you have any local auto-parts stores where you could get an ign.coil that's near just 10-bucks total ?
____ I'm left to assume that you don't have the stock Ducati ign.coil to try using ?
" this coil is 1.5 ohm which will pull too much current thru the points, I think I need a 3-4 ohm coil "
____ That 1.5-ohm amount of resistance does seem sort-of low for a 12v.system on a Duke,, but if you include a 2-ohm ign.ballast-resistor, then such a combo ought-to work-out fairly well.
__ Why-not just go-ahead & check-into what-all of such is available locally ?
____ I have another question, which I'll ask within your other more related thread.
work: "
Users browsing this forum: Google [Bot] and 69 guests
