DESMO Discussions (continued, here) Thread
Re: DESMO Discussions (continued, here) Thread
Postby DewCatTea-Bob » Wed Mar 06, 2013 12:17 pm
Harvey wrote:I fitted the cam
and found that the keyway was one tooth out, and the inlet lobe was about 6* advanced to the closing lobe.
joe46ho wrote:Could the problem with the keyway being off, and the intake lobe being too far advanced be due to these cams having not been originally intended for a single at all, but for a v-twin ??
____ That's a thoughtful thought ! ...
While I'd expect that the issue with the keyway-slot would still be logically straight-forwardly tied to TDC degree-wise (instead of being some odd amount off),, the issue concerning the phase-relationship between opening & closing lobes however, could possibly be due to your suspicion.
I don't happen to know if the opening & closing rocker-pin geometry-layout is any different between the singles & L-twins, but if their respective orientation-angles are laid-out any differently, then such a difference would of-course likewise differ the corresponding cam-lobes orientation, (respectfully, between the two camshaft types), also as well.
__ So if someone happens to have both types of DESMO-heads, pictures of both of their rocker-pin layouts would help to confirm any layout-orientation difference, and-thus whether your suspicion may be valid.
Harvey
Postby Harvey » Wed Mar 06, 2013 9:48 pm
joe46ho wrote:Well in the links i posted there are two different types I only posted the pictures from one link.. but one thing I don't get is this... I thought that conversion was very rare and not "common" by any means so why would they mass produce such an odd cam ? The other thing is this, when I emailed about the cam on eBay from Brooke Henry it was not one of these "conversion cams" so to speak, I specifically asked about the availability of a stock type replacement cam for the 350 desmo, and the reply was to that question (and there reply was as I said "we can make one for you, we just modify/machine a vtwin cam..." So back to that... Does that seem weird or would a desmo twin cams lobe size, orientation , etc actually work on a single ?
Joe
The Forcycle bike was a good conversion, so Forcycle Engineering must have been going to do a number of conversions, but didn’t sell them.
I would say that what V2 was purposing in the E-Mail was to take a twin cam blank, and machine it into a single cam, then grinding the profile that you wanted into it. Sounds like a good deal, depending on the dollars.
As far as I know the rockers on the twin are a different angle to the single, so a twin profile would not suit the single. Though the same 900 lift and duration can be used in the single.
Harvey.
Postby DewCatTea-Bob » Wed Mar 06, 2013 11:15 pm
By: LaceyDucati...
" - 48 bhp is from a severely modified head with a port higher and larger than a standard Bevel Twin head.
____ I find it a bit hard to believe that a std.450-Single cyl.head could possibly be modded-up well enough to develop an intake-port that's larger than that which a L-twin cyl.head can be.
For my 25 to 35% figure for increased air-flow, I was assuming an intake-port size of near 40mm for the L-twin head and only up to 36mm for the 450-head.
__ Intake-port dia.size & volume naturally make a relatively big difference in engine-performance.
" The factory engine is supposed to be a road bike development and one would assume it would be far short of race spec. "
____ That's certainly reasonable to assume, and I'M probably at fault to have assumed that we were discussing a 500-DESMO engine-head with an intake-port just-like that of a 900SS-head.
" I am sure Eldert could confirm this for you! "
____ No need for that at all,, as any argued-point from YOU, is more than sufficient !
__ It seems that I've miss-valued the likely difference in intake-port sizes, and-thus the extra 4-BHP is indeed no-doubt a figure that (if true) must have been taken directly off-from the crankshaft (rather than at the rear-wheel).
So no-doubt that 480-engine developed at least a bit more BHP than that 500-prototype.
" If you swap rocker arms around it will be noted that these variations in clearance change from one arm to another to some extent identifying inaccuracies. "
____ I-myself have never noted such, simply because I never bothered to investigate such a possibility,, as I was never much concerned with trying to obtain the perfect '0' closing-clearance on any case where a binding-issue arose.
__ For others who do (still) care, you've brought-up an idea which might-possibly coincidentally help diminish (at least) one side of their binding issues.
" - I would not run a road bike without springs but adding the bevel twin assister springs will overcome those problems. "
____ Right... While I've insinuated that VALVE-springs can be totally eliminated, such optional ROCKER-springs are still quite useful ! _ Not only for starting-RPMs, but also for rocker-cladder noise-reduction.
" - Obviously I agree with you here, I was using the term "shut" meaning sealing. Just trying to make simple statements without ending up writing war and peace. "
____ Of-course I had expected that YOU-yourself had no-doubt realized exactly what you had MEANT to state, and I (for one) had realized what you must've really meant,, however ALL of your post-readers ought not be expected to realize that such minor-detail wording-discrepancies weren't actually purposefully stated exactly as is.
So I thus felt the need to straighten-out the actual details.
__ I'd like to (once again) remind readers of my posts, that when I 'quote' the post-wording of somebody-else, I'm more than likely not meaning to specifically address THAT particular person directly,, but rather, I most-often merely quote their post-wording simply as a spring-board to help orient ANY reader, so as to help better comprehend the reasoning of my directly-following response-wording.
" Good theory but I have never come across a Desmo cam profile from either a bevel single or twin which cannot be run with a spring valve engine running suitable springs. "
____ Good-point of-course, which is why I had stopped-short of going-ahead & claiming that Ducati had ever actually bothered to go-on & take full-advantage of fully radicalizing their opening cam-lobes (in a manor which may more-likely leave valve-springs floating alone, [as springs do indeed have there limits, after-all] ).
Postby graeme » Thu Mar 07, 2013 1:35 am
Hello Nigel,
If you have time could you post what was done to the 480cc single you spoke of earlier to get it to the stage that it made that kind of HP?
How long did the cases last?
What happened to the Forcycle single?
Regarding desmo machining general,,,,
From my limited experience with 450's from back in the '70's 'till now, they are best described as "character building" especially when they were new off the showroom floor.
A friend bought a new 450 silver shotgun, which proceded to lighten itself by shedding cycle parts in the first 200 kms, then the electrics failed followed by many mechanical breakdowns etc,,,,,
When it was going it was a great thing. This was not very often.
Factory machining back then was hit and miss, some bikes were better than others, but they were all unreliable pieces of shit. (in my opinion)
And the dealers didn't care about the people that bought them. (again, my opinion)
They were not all the same either, parts varied from bike to bike of the same year and model.
So why do I still play around with them? :? :oops: They have character, and are great to ride.
Back then most non Japanese bikes were not well made and some worse than Ducati.
Bikes were not the precision machines they are today.
Postby DewCatTea-Bob » Thu Mar 07, 2013 5:50 am
" Regarding desmo machining general,,,,
Factory machining back then was hit and miss, (in my opinion) "
____ I'm hoping Graeme's (seemingly on-the-fence) post wasn't in any way partially inspired due to a sour-grapes attitude developed from learning the possibility that the factory-machined quality of his 450DESMO-head may-not have actually been up to the standards of the quality-work which he-himself has put-into his DESMO-cams !
__ And also, it was never my intention to directly insinuate that anyone who has already gone to the trouble of stoning-down there DESMO-cam (for consistently perfect '0' closing-clearance), had actually wasted their time with the effort,, (as the result of their painstaking-work certainly indeed produced rather polished mechanical-operation which can thus-then possibly come-into play [if shimmed to '0'] ).
____ My (possibly seemingly un-positive) discussion concerning the actual-NEED for such cam-lobe dressing, was posted merely to inform those who've heard-tale that most-all DESMO-cams weren't perfectly-machined by the factory, and-so also led to believe that probable damage would likely occur if their ("malfuncked") DESMO-cam is installed without first being properly dressed-out,, that, they ACTUALLY don't have anything to be worried & concerned about, as it's not at all important to achieve the 'zer0' closing-clearance throughout the closing-lobe's lift-duration, (since other like-minded factors are also redundantly in-play). ...
(Since this post is a response-posting [& not a reply-post], I'll refrain from overfilling it with the other related stuff which I'll instead include in my next associated-post. _ (So look below within THAT post, for further related details.)
" They were not all the same either, parts varied from bike to bike of the same year and model. "
____ That's rather quite unfortunate that (for some reason) Ducati didn't treat your country with the same respect as they did the USA ! - (Here, most-all stock Duke-models consistently carried the very-same parts as detailed within the parts-books !)
Perhaps the DUCATI-importer for your country requested that Ducati keep their price for newly-produced models as low as possible, even at the expense of having to employ miscellaneous/scrap-bin parts.
Dunkitty-dukes,
DESMO Discussions (continued, here) Post
Postby DewCatTea-Bob » Thu Mar 07, 2013 6:55 am
____ The reason behind my added concern for the owners DESMO-cams, is due to a commonly circulated email which was spread-around back around prior to late-2007 - (at least that was when it last came-by my way). _ I guess the email-message got most of it's circulation through being sent to ebay-sellers of DUCATI-parts.
Anyhow, another eBay-seller who was aware of me, (as DewCatTea-Bob has been my eBay-name), forwarded to me the following email with an attachment (which I-myself had already seen & read another [even older] version of).
I attempted to email the fellow (who had written the attached message-article), in an effort to explain my-own opinion as to why he need-not be so concerned as he seemed to be on the matter, but he never responded-back (even though my email was not returned as undeliverable).
I hope he's okay,, and if anyone here knows of him, then please try to convince him to join-up here.
__ I've never thought to actually get-around to posting all this before because I couldn't recall the name of the eBay-seller who had forwarded the email to me, so that I could then have a standard-way to search for that old email,, but as I was posting my previous-post here, I thought of another way to search-out the old emailing (so I could finally post it's contents here).
__ Here-below follows the forwarded-email within the highlighted area, with the author-fellow's attached DESMO-article (placed within the double-highlighted area). ...
Hi, I'm Bill Kearnes, bought my first Ducati in 1968, still have it. This article concerns my 1971 450RT that I restored a couple years ago. If you have any questions about the article, I'd be happy to give my answers. My background in mechanics is 45 years as an Aircraft mechanic (FAA licensee). My background in Motorcycles covers 54 years, first bike was a 1941 Indian Scout. These are my reasons for feeling qualified to offer this article to anyone interested in Desmodromic valve maintenance.
I'd appreciate it if you would forward this article to the person that bought the 450RT head, he may find it helpful.
Sweetening a Ducati cam!
What does that mean? Well, with the Desmo cam it means it will rotate 360 degrees in the head (once the valve clearance is set) with no resistance. This is assuming that the closer springs are disengaged from the closing rocker or the spring retainer as on the single cylinder engine. Why is this important, and why would anyone check it? Read on!
First off; this is not another article on how to adjust the Ducati Desmo valve system! That is in your shop manual, and numerous Websites have owners & mechanics interpretations of those manual instructions. If you don’t know how to adjust your valves then I don’t think you should read any further. If you regularly adjust your valves and are comfortable with it and all other aspects of cylinder head disassembly and reassembly then read on. This may be a very enlightening experience for the Desmo owner. The procedures I list here can be harmful to your engine if not done correctly and carefully, period!
If you damage your engine, I will not be responsible. You just aren’t the Mechanic you thought you were!
Now that you’ve read my Disclaimer, it’s time to learn even more about your beloved Ducati.
I recently restored/rebuilt a 1971 Ducati 450RT and after a complete disassembly of the engine for inspection and repair, as necessary, I reassembled using new gaskets by the book. When the bottom end was complete it was installed in the frame minus the piston, cylinder & head. With the head on a fixture I made I began adjusting the valve clearances, again by the shop manual instructions. Finding “0” clearance on the closer is a lengthy trial & error process but with patience, sufficient shims & a means of modifying those shims it can be accomplished. This is of course done with the cam at the TDC position. When 0” clearance is reached, the high point of the closer lobe will just be slightly felt as the cam is rotated. The opening rocker is an easier process, but the same items are needed, shims & emery paper (I used #320, #400 & #600). Once both closers are set to “0” clearance & the openers are set to .004” as the book prescribes, everything is good, right? Wrong!
With both valves clearances set to spec. and the closer springs disengaged; the cam should rotate freely for 360 degrees, with only the very slight (hardly detectable) resistance when the closer rocker comes in contact with the high point on the lobe. That’s the way it should work, if the cam was ground correctly. My cam was not ground correctly, and when I tried to rotate it I had severe resistance at the transition point of valve closing on the intake & valve opening on the exhaust. On the Desmo cam, the intake lobe is ground for a fast opening & slower closing of the valve, the exhaust lobe is the reverse of this, a slower opening & fast closing of the exhaust valve.
Not knowing what to do to correct this resistance problem, and no mention of the problem in the shop manual, I went to the Internet. I searched every website I could find, and no information could I find that even resembled what I considered a major problem. Was I the only one? I doubted that. I don’t think anyone else ever checked for it before. When everything is done by the book it should be good, right.
I think a lot of Ducati riders and especially mechanics put far too much faith in Ducati’s Design & Quality Control people. If you adjust your valves per the book, you will never know if this condition exists in your engine or not. Think about that for awhile. I don’t mean to alarm anyone, but think of what might happen if your Desmo engine is like mine!
Unable to find any good corrective action on the Net, I decided to do what I thought best. I increased the opener clearance on both valves to .007” and rechecked for resistance. Still there, but not as bad. Not wanting to go any looser on the openers, I increased the closer clearance to .006” to get to a barely acceptable amount of rotational resistance. This means that I had .009” too much metal somewhere. If I had gone a couple more thou on the closers it probably would have gotten rid of the remaining contact. I didn’t do that because if you must have the closers that loose, might as well remove them and let the springs do all the work.(even though the Desmo springs are not the same as the 450 springer engine, they are weaker, from, I think the 160 engine. They are primarily there to insure positive closing for a better idle performance) In my case the pieces & parts would probably last longer had I have done just that!
Having gotten the valves as good as I could, I installed the head & finished the bike. It started easily and ran fine, with little if any valve noise. Kinda hard to tell with an open short pipe.
A couple months went by and the valve problem kept bugging me. Why should a beautifully designed Desmo head be so poorly executed that the Desmodromic system is useless as originally designed.
One thing I should mention is, when I disassembled the head to inspect the valves and seats all parts were reinstalled in their original position. Only a light lapping of the valves & seats was necessary to bring them to perfect condition.
I finally decided that I could not leave the problem alone, it had to be fixed. I contacted one of the old (read experienced) Ducati tuners in LaSalette Ontario Canada, and told him my tale. Yes, he’d seen the problem, & yes it could be fixed. He said old time racers would stone the cam to bring it to an acceptable profile and the rockers could be shimmed properly. Never having met this guy or knowing anything about him, I decided to check his story. I then emailed another long time tuner in Australia, a Ducati Guru, and he confirmed that to get the Desmo system 100% that in fact the cam would need work and hand stoning was the way to do it. (I’m paraphrasing both Gentlemen) Not being real excited about reshaping the only Desmo cam I had, I started looking for another, a backup. I did find a 450 cam on ebay and got it for a reasonable price. Now I’m almost ready to start hand grinding my cam! Have you ever heard of anything so insane? All those years of seeing those fancy cam grinders at work, with the massive grinders following a master cam and turning out beautiful camshafts. Here I’m going to attempt something similar by hand, I must be crazy!
I actually thought about this for a couple months, questioning my mechanical ability & assessing my desire to reshape a cam by hand! After all, you screw it up; you don’t go to the local M/C shop and buy another cam for a 30 plus year old bike. I had a second one, but I also had doubts about doing this correctly. Actually it’s not that hard to do, provided you have the correct equipment, take your time & don’t expect to finish the task in a weekend. I would need a different fixture to hold the cylinder head at a comfortable working height. I didn’t want to have the head rolling around on the bench while installing shims, rockers, half rings, etc. I would also need a cam holding fixture that allowed easy stoning of the cam with a guard to protect the lobes not being worked on. I would also need an assortment of small sharpening stones, from medium grit to very fine for polishing the completed cam. A good place to find the stones you need is;
Hall’s Arkansas Oilstones,Inc (website, http://www.hallsproedge.com/index.html)
For the head holding fixture, I used 4 lengths of threaded rod 3/8” diameter by 2 feet long. These go through the head with a nut & washer above & below the head. Four holes in a thick piece of wood with nuts and washers above & below clamped in a workmate style bench hold the head at shoulder level.
This needs to be stable and comfortable because you’ll be assembling and disassembling the head many times before you’re finished.
I also made a wooden fixture to hold the cam with slots cut to hold an aluminum guard that would hold the cam in place and protect adjacent lobes.
I received the seven different stones that were ordered, so it’s time to get started.
I removed the head from the engine after setting the engine at TDC compression stroke with cam timing marks aligned. With the head mounted on the holding fixture, I rechecked the valve clearances & found them to be as they were set months earlier. I really didn’t think it would fix itself, just thought I’d check.
I disassembled the head, inspecting each item much closer than I had when the engine was disassembled. I found some areas of wear that had gone unnoticed earlier. The closing rockers had very slight wear on the cam follower pad and the rocker pivot pins were slightly loose in the head, barely noticeable. The rocker pins were not worn so the looseness had to be in the head as a very slightly enlarged hole. The closing rocker pivot pin is shorter than opening rocker pin because it sits between the cylinder head hold-down bolts. This would give less area to support the pin and may have contributed to the looseness. The reason, I believe, for the looseness is because the valves were adjusted by the shop manual and the opening/closing rocker interference caused excessive strain on these pins (with less support) and caused these holes to elongate very slightly. The head was not unusable, but it’s not like new either. This is also something to keep in mind when setting the closer clearance even if you don’t have opener/closer interference!
With closing rockers removed & the exhaust valve spring disconnected I measured the rotational torque required to turn the cam, intake spring only, required 25” lbs. with dial indicator torque wrench. Disconnect the intake springs, connect the exhaust valve springs and 35” lbs. required. This amount of force would easily cover-up the interference force and allow it to go undetected if checked with springs in place. After this was known, I disconnected both valve springs and all future checking and setting will be done without valve springs.
I refinished the closing rocker cam follower pads with #400 then #600 wet dry paper, just enough to remove the wear marks. In theory, in my theory at least, these pads should not be worn! If the cam is ground properly and the valves adjusted properly, there should be little or no pressure exerted on the closing rocker arm unless overreving has occurred and valve float is approached. I would expect to see this wear on the openers, remember the rotational torque required to turn the cam against the valve springs? My openers were in fine shape with no detectable wear!
After refinishing the closer cam follower surface, I reinstall one rocker and adjust the clearance to where the rocker can just faintly be felt as the cam is rotated, a .001” feeler gauge cannot be inserted when on the high side of the cam. When the feeler gauge is inserted on the low side of the cam a noticeable drag is felt when the cam is rotated to the high side, perfect. Now remove that rocker, install the other and adjust the clearance just like the first. Leaving that rocker in place, turn the cam to the TDC position. On the single cylinder engine the timing dot will be at the 6:00 o clock position. Install the opening rocker for that valve and adjust the clearance by changing opener caps or honing the existing cap to get the desired clearance. The shop manual calls for .004”, I don’t think .005” or .006” is too bad if you don’t have the correct size cap. The opener clearance will tighten up as the valve and seat wear, the closer will loosen up as this wear occurs & the valve goes deeper into the head.
Now, if the cam is ground correctly, you should be able to rotate the cam 360 degrees with no resistance, zero, nada. I would be very surprised if that’s the result you get. Mine was very difficult to turn through the valve opening and closing. I felt like I was very close to breaking something the resistance was so high, remember this is metal-to-metal, no springs here. The area of the cam that had the most resistance was when the valve was completely open and going down the closing side of the lobe on the intake valve & on the opening portion of the exhaust valve lobe. To mark the exact position on the cam that needs work, remove the opening rocker, remove the cam, with Dykem, coat the opening & closing lobes of the cam for that valve. Reinstall the cam, the opening rocker, bearing support cap and drive gear.
Now, when you rotate the cam the Dykem will be rubbed off at the location of interference on both the opening and closing lobes. I also put my dial indicating torque wrench on at this point to see how much rotational torque is required to turn the cam. Mine was a scary, 17” lbs. on 1 valve and about 19” lbs. on the other! I don’t understand how it lived as long as it did. Remember that I only have one valve installed with no valve springs. This photo (above) shows the Dykemed cam in place with 1 set of rockers ready to be checked. Note the second valve and rockers are not installed at this point. This next photo shows the high point on the closing lobe, the area that needs work to eliminate the rotational resistance, the Dykem has been rubbed of at the high point.
Remove the opening rocker, and the cam, being careful not to disturb any of the remaining Dykem. Put the cam in the holder & install the guard. Now with a small medium grit, well-oiled stone carefully begin to hone away the high spot on the closer lobe. If you remove material from the opener lobe you will affect valve timing, that’s a no no. The high spot will be indicated as the area where the Dykem is missing. Maintaining squareness of the cam lobe is very important here, as is the contour of the lobe, centered finger pressure above the lobe does a good job at this. Don’t get in a hurry, this takes a long time, if you get tired, quit, come back later and you’ll get better results. When you think you’ve removed enough metal use a fine stone to put the polished surface back on the closer lobe. Clean and reapply Dykem to both lobes and reassemble in the head. Now give the cam a turn, the resistance should be less, use the torque wrench to see how much less. You’ll probably be surprised at how little the improvement is. Don’t despair, it will take many, many times of the same thing to get to a sweet turning cam. If you try to use power tools or aggressive coarse stones be prepared to find a replacement cam.
I did this on my cam probably 20 times per valve to get very close to perfect. It may not seem worth the effort if your engine runs OK, but those unknowns’ bugs the hell out of me. Now both my valves have less than .001” on the closers & about .0055” on the openers. Only the slightest hint of interference at the areas of concern when I started this project. With my Snap-On 0-300 in. lb. torque wrench, I get no reading when rotating the cam. During the process I could easily read 1 ½ to 2 “ lbs. of drag at the bad spots. Nuff said.
I am completely happy with the outcome, but it didn’t come easily, a lot of assembly/disassembly and this is something that should not have to be done. Ducati should never have let stuff like this leave the factory. This problem was on an old single cylinder engine that was otherwise in very good shape, showing very little, if any wear. I wouldn’t be surprised if the twins, both 2 valve & 4 valve models have the same problem. I also don’t know the twin shop manuals, I have read numerous books on the twin & never seen a reference to this problem, although other design problems are addressed. I have seen many articles on the net about twin cylinder Ducatis losing rocker arm hard coating. There are also many fixes for this problem, new coatings by different aftermarketeers, modifications by Ducati, and excuses by Ducati as to who and how the hard coatings were applied. I’m by no means a Ducati expert, but if the twins have a similar problem to the singles I can see why the hard coatings failed. Considering the higher revving twins I would think the hard coating could fail even though it was correct and installed correctly.
That’s my opinion, I have nothing to back me up other than, the way mine was built by Ducati it could never have worked properly and lived a long life. I think it will now outlive me.
I guess it comes down to; If you don’t check it you’ll never know!
(Update; I just checked with another Ducati “Expert”, in Florida, he said he’d never heard of the problem. There you go, if you never check it you won’t hear of it either! )
Bill Kearnes
November 2005
____ I'd be interested to know how many of us DESMO-owners have already received/read this particular authored-article by whatever means (if not through an email), and how long-ago.
I've also seen another shorter version (which may've possibly been partially-written by another source) which seemed to have wished to expressly scare DESMO-head owners into selling-off their 450DESMO-heads (thru eBay or whatever).
__ Anyhow, I've long been intending to bring-up all this stuff (posted in this thread) ever-since this w.site got on-line, but it seems that my time for getting-around to it had since been spent on other activities.
It's a fairly-good thing that I've brought-up my-own semi-opposing view-point concerning the issue in question, BEFORE allowing others to become tensed-up about this actual non-issue.
Desmo-Cheers,
Postby graeme » Thu Mar 07, 2013 7:18 am
Hello Bob,
Re your post 2 above,,,,
My own feelings and experiences with Ducati 450's is from personal real time experiences, not what someone else has told me, so I won't be dissapointed by what others say about their downfalls.
So I know of the machining and consistancy downfalls associated with these bikes.
There are much worse makes of the same era. (ever rebuilt a Norton Commando? Ducati singles are precision clockwork in comparison)
I like to try and maintain my bikes as best as I can with my limited knowledge and tools as close as they were originally designed. (with a few modern upgrades to keep them running better, longer)
I also enjoy learning from the tallented people on this site.
They are an enjoyable, good looking, good handling, bikes and I find them enjoyable to work on and ride. (to me)
I think people get mixed up with the myth that these bikes were built with Italian passion and magnifesence when they were built to make money with as little outlay as possible.
They may have been designed with Italian passion, but not always built that way.
We in Australia did get some of the more desirable models when other countries importers weren't interested, so that was a good thing.
But the dealers (some)back then didn't really care too much about customer service. Of course I can't say that about all dealers in Australia.
Doesn't matter, I have a Ducati single and I'm more than happy with it. :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
ps, I wouldn't sell the Norton either,,,, is this a genetic flaw? :oops: :oops: :oops: :oops:
RUSH-JOB done
Postby DewCatTea-Bob » Thu Mar 07, 2013 7:53 am
____ This post has been added for the temp.purpose of flagging this thread so that others can now be aware that the last posted-post has finally been completely finished.
Temp.Cheers,
Postby machten » Thu Mar 07, 2013 12:09 pm
No surprises for me in the quote DCT-Bob put up. I have had the same experience with singles desmo shimming and binding. I guess I'm lazy, I just took the approach of running the closer as loose as it needed to be in order to run the opener in spec on the theory that DCT-Bob has already espoused. Personally, I'd prefer it was "perfect" with 0 clearance on closer (if for nothing else, it would be a lot quieter on the top end and I think removing lash is a good thing if possible).
The thing I don't understand from the previous posts regarding taking out the closer lobe is how that affects what I understood as the overall purpose of the desmo setup - to eliminate valve float and bounce at high RPM. If taking the mechanical closer out for anything other other than inital change of direction momentum is a good idea, was Dr T wrong?
Postby DewCatTea-Bob » Thu Mar 07, 2013 1:27 pm
" The thing I don't understand from the previous posts regarding taking out the closer lobe is how that affects what I understood as the overall purpose of the desmo setup - to eliminate valve float and bounce at high RPM. "
____ First, whenever we discuss this stuff about desmo.function, we should let it be known whether the particular DESMO-head being discussed-of is with or without it's originally-included stock valve-springs.
__ Anyhow Kev, it seems that you must've SKIMMED-through those posts of mine (which stated that once the valve has been sent on it's way to it's seat, that the remainder of the closing-lobe's track-face THEN no-longer needs to exist), cuz otherwise you ought to have understood the answer to that which you've brought-up...
__ Suspecting that someone may not comprehend my extended-wording (in those posts), I also included a picture of a closing-lobe with a red-line added for depicting the larger-section of that lobe which is not really needed for any really USEFUL purpose. _ So that should've made it pretty-clear that I never meant to indicate that the ENTIRE closing-lobe be taken-out, as it's closing-ramp is indeed very IMPORTANT to perform the intended act of making-SURE that the valve is getting closed (beyond the capability of valve-springs).
Ya-see once the closing-lobe's closing-ramp has pulled/(launched) the valve towards it's seat, then that's ALL that's important (from the desmo-system),, cuz then after that point, the REST of the closing-lobe's track-face serves no purpose that's not already covered by other (rather redundant!) acts-of-force* which hold the valve shut against it's seat (independently, without need of any further help from the closing-lobe) ! _ So since the MAJORITY of the closing-lobe's mass is not really needed for any important purpose, that's why I've pointed-out that THAT majority-section of it may as well not even exist.
(* Those "acts-of-force" originate from the valve-springs & internal cylinder pressures.)
__ Now instead of allowing the reader to ASSUME on his own that I've expected springs to remain involved whenever I've stated that the section of the closing-lobe's track-face following the lobe's closing-ramp is of no real use, I'll now clearly declare so...
Once that useless section of the closing-lobe has been removed from the camshaft, (if indeed anyone ever actually bothered to go-ahead & do so), then closure-springs -(either the stock valve-springs or an optional rocker-spring) would of-course then have to be more depended upon for starting-purposes. _ But then of-course that would still be the case ANYHOW, whenever the closing-clearance became opened-up past the recommended zer0-clearance ! _ (Which is indeed more common than not !)
Also, the resulted lash-space (without the main-bulk of the closing-lobe), would then of-course leave much greater room for the closing-rocker to possibly slumber-around within, however a rocker-spring would make-sure that it stays-put in it's normal running-position.
" If taking the mechanical closer out for anything other other than inital change of direction momentum is a good idea, "
____ I'm not sure of how I should interpret the meaning of that wording,
so can you reword it in another way ?
" was Dr T wrong? "
____ I'm sure that if Dr.T had always gotten his way, then I & most everyone-else would've been much more pleased with (at least) Duke-singles !
__ I'm reasonably sure that the extended track-face (which it's cam-follower tracks) ORIGINALLY had an intended purpose, but after being adopted into std.mass-production, that purpose became noted as quite redundant and-thus allowed to become ignored.
____ (Long ago, I thought-up my very-own [radically different!] desmo.system, [which I believe to be much superior in concept],, but ultimately, it would have to be tested to determine if it could possibly hold-up under actual use.)
Users browsing this forum: No registered users and 165 guests
