Kick-start slip on narrow case
Re: Kick-start slip on narrow case
Postby DewCatTea-Bob » Sat Sep 29, 2012 6:57 pm
" I increased the chamfer using my bench grinder, and the whole thing re-assembeled perfectly! "
____ So I gather that your previous fitment-issue was basically due merely to the kit's spacer-tube having been too fat (at it's inner-base) to be able to fit squarely at it's intended position right-next to the raised boss below it.
If so, then that seems to indicate that that kit was not well prepared. _ Your other/second kit should be checked to see if the same situation will occur with it as well.
__ What size drill-bit did you use to actually drill your hole with ?
Larger drill-bits tend to wonder off-center when trying to drill without a good-sized punch-mark on the intended drill-spot, (which is what I HAD assumed had happened in your case),, so that's why I recommend STARTING the hole with a 1/8th-bit first.
__ Your next job (on whichever Duke) should go just fine for you !
Postby JimF » Sun Oct 07, 2012 5:00 am
http://www.motoscrubs.com/Narrowcase_Ki ... Repair.htm
I'm hoping we can put this topic to rest with a "how-to" page.
The link above is also on the "Tech" page.
Let me know if you think it has mistakes or needs further information.
I have to do the Mach 1 and I have to go back and put a locking washer on the clutch hub nut of the 'Mark 3', so I will have the opportunity to take more photos.
DanM
Postby DanM » Sun Oct 07, 2012 1:25 pm
Jim, Excellent article. The pictures are a great help. Thanks for taking the time. Dan
