Help with wiring please
Rare Red&Black 60-w.alt / Alt.PHASE-timing
Postby DewCatTea-Bob » Thu May 31, 2012 5:41 am
wcorey wrote:
DCT-Bob wrote:You have the odd 60w.alt with the quite rare black & red alt.wire-leads,
Bob, this of course has me very curious as I wasn't even aware of it's existence. From the small pics it appears to be at least extremely similar the yellow wire version, though I guess if the only difference were wire color than it would have been pointless to change it (but stranger things than that have popped up out of the factory).
So you're inferring that the two coil sets are wound and/or connected differently?
Otherwise it would seem that the wires would be interchangeable.
____ This one black & one red, (as opposed to two yellows), alt.wire-leads subject has been brought-up on this w.site before.
Here's the what's-what on this matter which I happen to be aware of...
__ When I first encountered a Monza with these strange wire-colors, I then assumed that the original yellow/yellow alternator-stator had been replaced under warranty with a replacement-unit which had been built with whatever the original-defect having been addressed & updated.
However due to the eyebrow-raising number (with the red & black) which I've since come-across plus others I've heard tale of as well, I've come to gather that that presumption is probably not the actual case,, and that (for some unknown reason), Ducati had a batch of such fitted stators produced & ORIGINALLY installed.
I've never had such a stator of my own but assume them to be just the same as the regular alt.stators (with the y/y.wire-leads), since all the other electrical-workings remain the same on either equipped DUKEs.
So therefore I had not meant to infer that anything else was different.
wcory wrote:
DCT-Bob wrote:In either case, one of them will run the ign.system while the other won't (due to alt.rotor-timing) !
Since both winding sets reside on the same core-posts, wouldn't the rotor-pulse-timing be the same on either?
____Well yes, the "timing" of the (raw/AC) power-PULSES would of-course be the same for both alt.windings,
however since the two windings are 180 out of phase, the required PHASE of the needed DC.power-pulse is thus-then not timed the same from both alt.outputs ! _ So after rectification, ONE of the alt.outputs is left unused,, and-thus the associated diode's output would happen to be dead during the time when the ignition would use alt.power, (assuming the battery happens to be low).
__ To this reply above, one may be inclined to think that the situation is to be actually blamed on the involved diode's polarity-connection rather than the 'alt.rotor-timing',, but it's actually possible to flip which alt.wire-lead's rectified-output is live or dead (for powering-up the ignition), by resetting the alt.rotor's timing either 60-degrees retarded or 60-degrees advanced !
____ This kind of stuff all being well understood, it then ought to be realized why the stock charging-system must be thought-of as "duel half-wave rectification" rather than ordinary 'full-wave rectification',, as others may possibly jump-to-conclusion of.
(I wonder if MotoMike has ever yet seen the light I once tried to shine on this issue we once had !?)
Set-up of the Simplest Charging-system
Postby DewCatTea-Bob » Thu May 31, 2012 11:14 pm
By: lloydy1...
" Thank you for your input on this, it sounds a lot easier now that I haven't got to solder and unsolder wires etc, "
____ Indeed it is easier to install the simplest charging-system setup,
HOWEVER, if you still/already have the alt.stator out where you can handle it, then it's best to go-ahead & replace it's attached pair of alt.wire-leads,, cuz the original wires are well known to have their insulation-jacketing/coating to have become well deteriorated by these later days (actually 'decades' !) !
So while you have your alt.stator available to upgrade, I really suggest that you replace both it's wire-leads (one at a time!) with matching/same colored wiring, that's no smaller than 16-gauge,, (and if you can find such, it would be best if your chosen black wire were actually black & yellow striped, and also the red-wire with a yellow-stripe, as well).
" as I said in my previous messages I am a novice when it comes to the electrical side of things, "
____ Since you're working on your Duke, then you probably have at least SOME of the (non-technical) understanding of bike-electrical-workings that many mechanics have,, and if so, I can then direct you through (at least) this simple charging-system which you require for your Duke-project.
So be sure to post any related questions of whatever you're not real certain about, so I can then assure you of proper procedure.
PS.. If anyone cares, I've now had a little time to edit & add to my previous-posts within this thread.
lloydy1
Re: Help with wiring please
Postby lloydy1 » Fri Jun 01, 2012 5:28 am
Hi Bob,
You say;
Either alt.wire-lead will do your expected job, however only ONE in particular (of the two) will keep your ignition running even if the battery becomes discharged !
Do you know which particular wire I would use under this installation?
Cheers, Dave
Postby Rick » Fri Jun 01, 2012 3:39 pm
Dave,
You have a really nice motorcycle there- my advice is to just get one of these:
http://www.electrexworld.co.uk/cgi-bin/ ... aSTK_2d160
I know you currently only want a tail light and a horn, but that could change- many states require a constantly lit headlight and for good reasons.
The Electrex alternator and a Dyna coil will cost a few hundred dollars, but you'll have a good system with parts and technical support available.
I've spent hours reading through posts on the Ducati alternators- extensive testing with lots of good information, but ultimately not conclusive- there doesn't appear to be a 'follow this schematic with these parts' answer- especially for someone reluctant to solder. Most of the posts on the subject are by and for guys who enjoy electronics, and they know what they're doing, but if riding around with an ammeter trying to find the right combination of bulbs/coil wiring/etc doesn't appeal to you, forget about it and buy something that works.
You could sell whatever it is that you have on Ebay and get some of your money back, plus, if you ever decide to sell the motorcycle I think most buyers would prefer a nice 12v system that charges a battery and uses readily available bulbs.
I'm not wealthy, and don't throw money around, but the goal is to enjoy your motorcycle- sometimes spending money is the best option.
lloydy1
Postby lloydy1 » Fri Jun 01, 2012 4:11 pm
Hi Rick,
Your right!
I have been toying around for some time now with the very same thought and I was kidding myself about sticking with the original bits and bobs, but the truth is the bike is nothing like original and I want it to ride and enjoy and if I am worried about it being reliable, what you say makes complete sense.
You were the push that I needed to make my mind up. Thanks. ;)
Dave
Postby DewCatTea-Bob » Fri Jun 01, 2012 4:17 pm
" Do you know which particular wire I would use under this installation? "
____ If I did, then I already would've included that fairly important info.
A logical guess would be that the black alt.wire-lead would be the one cuz the red-wire would likely be expected to only help charge the battery.
The way to find-out if you have the correctly timed alt.wire-lead, is to first start the engine with the battery connected and then bring-up the revs (to about 2500-RPM), and then disconnect the battery (to discover if the engine still runs or not).
__ If you ever want the lights to also remain working extensively (without the battery becoming discharged), then another diode connected to your unused alt.wire-lead is all that's really necessary. - (Suitable diodes can readily be found for just a couple-bucks each !)
However in that case, if you run long periods at higher RPMs with lights off, then a regulator ought to be included to protect the battery. _ OR you could instead include a switch along with the 2nd-diode, so that such excess charging-power could simply be turned-off whenever wished.
____ I see now that you've responded positively to Rick's post, so I'll break-off my posting (at least for now).
__ There are a few different aftermarket systems (such as Rick has found) to choose from. _ Most are higher AC-frequency and thus will not run the ignition without a charged battery !
You may care to check-out the reports given by others who have gone with the aftermarket-system option.
Your decision will very much likely determine whether you begin riding your Duke relatively soon, or perhaps delayed until months from now.
lloydy1
Postby lloydy1 » Fri Jun 01, 2012 4:58 pm
Hi Bob,
can I say I have taken a lot from your input and it has been very much appreciated indeed. But with my limited ability with electrics, I feel it makes sense that I go with something that seems straight forward and trouble free, so once again thank you for sharing your knowledge concerning this matter.
I have gone with this option. link here http://www.classicducati.com/index.php? ... ductId=217
I am hoping this will suffice.
Dave
Postby DewCatTea-Bob » Fri Jun 01, 2012 5:30 pm
" But with my limited ability with electrics, I feel it makes sense that I go with something that seems straight forward "
____ Well Dave, actually there is NOTHING that's more "straight forward" than the simplest circuit which I was particularly directing you towards ! _ So relatively simple & easy it is, that a kitten could do it for you.
__ You should read (& possibly understand) the related installation-instructions BEFORE you make an aftermarket choice !
" I have gone with this option. "
____ Now I'm wondering if you had completely read my entire previous post !? ...
Hopefully Rick has researched & steered you towards the BEST aftermarket-system for YOU !
SubaruPaul
Postby SubaruPaul » Sat Jun 02, 2012 12:40 pm
DewCatTea-Bob wrote:PS.. If anyone cares, I've now had a little time to edit & add to my previous-posts within this thread.
Yes , many of us care. Thanks for all you contribute and teach us. You are the main reason for which I take the time to be here and try to learn. Count me in as another guy who just plain dislikes electrical work and appreciates to no end the lessons taught day in and day out here with you , Bob.
Cheers!
Inspiring-praise !
Postby DewCatTea-Bob » Sun Jun 03, 2012 4:51 am
SubaruPaul wrote:Yes , many of us care. Thanks for all you contribute and teach us. You are the main reason for which I take the time to be here and try to learn. Count me in as another guy who just plain dislikes electrical work and appreciates to no end the lessons taught day in and day out here with you , Bob.
Cheers!
____ Well thanks for that insight, as it feels nice to get a pat-on-the-back once in a while !!
__ Because being a Duker was once so important to me, it's become my hopeful-wish to have all other Dukers realize at lease that which I have come to know about them.
