RT Rebuild and questions
Re: RT Rebuild and questions
Postby Eldert » Tue Mar 27, 2012 1:34 pm
graeme wrote: I removed the std springs and fit small springs like Pantahs use but lighter.
nice light spring there Graeme . from what type of Ducati are they or are they one offs ?
if so who supplied them ?
Regards Eldert
Postby graeme » Tue Mar 27, 2012 8:45 pm
Hello Eldert, I had bevel twin springs copied but 1/2 the weight, these are either 2 or 4 kg? It was many years ago but they are definately 1/2 bevel twin strength. PM me a postal address and I'll mail you some. Graeme
PhilA
Postby PhilA » Tue Mar 27, 2012 11:33 pm
Have you asked Gowie if he has any R/T TS bits? They are just the sort of thing he may have tucked away somewhere!
iangowanloch@bigpond.com
Phil
Postby graeme » Tue Mar 27, 2012 11:49 pm
Hello Phil,
email sent to Ian.
I am looking forward to another of Ian's replys full of Ian's gems.
Someone should collect Ian's stories and record them for future generations.
Postby Eldert » Wed Mar 28, 2012 7:43 am
the Italian Scrambler club Amici Dello Scrambler is also having some RT bits reproduced .
plastic sidecovers , fenders , tank and seat . the next items to be remade are the snailcam chainadjusters and
the sidestand .
Postby graeme » Sun Apr 01, 2012 12:42 am
Hello Phil, Ian couldn't help with the bits I need,
Hello Eldert, Amici Dello Scrambler do have what I need, thank you.
The engine mount bolts that were on the bike don't look right.
I have the pictures of the parts manual but not the descriptions of the parts.
Can anyone tell me the size of the engine mount bolts?
The two front mount bolts 91.050 / 055
The upper rear bolt 063
The front foot peg and through engine bolt 020
The rear foot peg and lower engine mount bolt 69.010
Links to Threads Concerning M-M.bolts
Postby DewCatTea-Bob » Sun Apr 01, 2012 7:52 am
" The engine mount bolts that were on the bike don't look right.
Can anyone tell me the size of the engine mount bolts? "
____ You might want to check-through the following threads before buying stock motor-mount bolts somewhere.
viewtopic.php?f=3&t=336
viewtopic.php?f=3&t=346
- Bob
Postby graeme » Sun Apr 01, 2012 8:57 am
Thanks Bob,
My '74 450 has upper and lower rear engine mount bolts that are 10mm. (the front 4 bolts are 8mm)
The R/T came with the lower rear 10mm, the upper 8mm and the forward foot peg 8mm. These look like standard bolts, but the two front 8mm bolts look like they came from a cheap hardware store. (the front holes in the cases are egg shape, witnessing loose bolts)
10mm will fit the frame and the rear upper and lower cases, but the forward foot peg hole will need to be drilled to fit 10mm.
I'll take the advice offered and use 10mm bolts.
Postby wcorey » Mon Apr 02, 2012 12:19 am
I have two '71 R/T chassis and one motor, the configuration is the same on both frames and the motor but I don't know if they could have been previously modified. The upper and lower rear motor mount bolts are 10mm, the front peg bolt is 8mm as well as the two front mounts. Doesn't seem like the foot peg bolt would need to be 10mm...
R/T / WideCase Footpeg-bracket Mounting
Postby DewCatTea-Bob » Mon Apr 02, 2012 5:30 pm
" Doesn't seem like the foot peg bolt would need to be 10mm... "
____ For street-riding that stock bolt is sufficient but, over 200-pound riders coming-down from jumps (while standing on pegs), causes the support-bosses (of the motor-case) to crack and eventually bust-off !
So for spirited off-road riding, wide-case models such as the R/T, ought to have the overstressed boss issue addressed so as to increase the strength of the foot-peg mounting areas.
Dukaddy-DUKEs.
