1966 250 scrambler transmission issues
Dave354
Re: 1966 250 scrambler transmission issues
I remember I had the same issue many years ago, making sure the selector drum tang was in the neutral position and the selector box correctly aligned… good luck
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Triumph Tiger 1200
Cornwall, UK
Just a thought…in my experience a second person is useful when trying a gearbox on the bench. You often need to turn the input and output shafts while trying to change gear so 3 hands are needed!
When operating normally, everything is rotating so the dogs will find their places easily. Not so when static on the bench.
(Apologies if teaching granny to suck eggs)
If you cable tie the clutch lever back and raise the rear wheel clear you can rotate the box with the back wheel with one hand while running through the gears with the other . This will also show how well the clutch frees and spins.
Users browsing this forum: Boxprod and 45 guests
