450 linkage and selector box problem
IanHood
Re: 450 linkage and selector box problem
Postby IanHood » Fri Aug 29, 2025 1:08 pm
I had a similar issue with mine and it was largely down to flex in the connecting rod. Yours is much longer than mine and would probably flex more. Fixed mine with a larger diameter connecting rod that eliminated the flex.
Postby blethermaskite » Fri Aug 29, 2025 3:26 pm
Hi Graeme, I'm inclined to agree with Ian, I also had an engagement issue with my 350 when I converted it to rearsets many years ago using a 6mm connecting rod.......too much flex...... changed to 10mm tube and it was fixed, might be worth a try? also have you got a 'straight' alignment between the pedal and the engine gear lever?
Cheers, George
Postby graeme » Sat Aug 30, 2025 6:22 am
Thank you all for the advice, I appreciate it.
I changed the front rose joint to a clevis.
The other end is LH thread and both clevis are RH thread.
So it is a lot better to get 1st and 2nd
Still work to
Postby graeme » Sat Aug 30, 2025 6:27 am
[quote="graeme"]Thank you all for the advice, I appreciate it.
Still work to do when I get the new return spring.
But we are going in the right direction, thank you all !
Postby Duccout » Sat Aug 30, 2025 7:10 am
BTW, great looking bike! Please show us some pics when it is finished.
