250 racer engine set up advice - missing power?
bendik
Re: 250 racer engine set up advice - missing power?
Postby bendik » Mon Sep 09, 2024 8:13 am
LaceyDucati wrote:Horsepower figures are only relevant to compatible tests, historic factory figures are crankshaft HP and invariably optimistic. 22 rear wheel horsepower although low in "race" terms for a 250, it is probably better than any original 250 model. However a 75.75mm piston will give well over 250cc.
Firstly is it a race piston and more importantly did you measure the CR, maybe a photo of the piston would help identify it. You could be losing power by either too low CR or possibly by too high CR with poor piston shape. 1.2mm squish is large and you will be losing some of the benefit of a squish type head. Mind you, you will need to ensure that the squish is consistent and angled correctly before lowering it. With everything else correct, you can run down to 0.6mm safely and I have gone tighter. With a good squish and piston shape I've not found it necessary to use more than 34 to 35 degrees BTDC using a single plug and have run around as 31 to 32 degrees using a twin plug (for a 250).
Cam timing can only be analyzed and compared if you have all the opening and closing figures. Either initial lift or better still 1mm lift, with the clearance used when taking those figures. Lobe center figures can then be calculated from a full set of figures and will indicate whether you are significantly out. Otherwise you are not comparing like with like and you can make any number of incorrect assumptions. I must say that over the years I have been surprised how many "race" cams are similar in performance and seldom will you achieve wildly significant changes by just swapping a cam. Also I have found in tests, the cam generally needs to be around 6 degrees out from "stated figures" before you start to see significant change in HP on the dyno. That doesn't mean small losses don't matter, as all those small losses eventually add up.
Poor cylinder head flow could also be to blame....There are many elements of a race engine that add up to good performance and all you can do is go through and check everything and experiment with one thing at a time. However from my experience if the head doesn't flow well you will be ultimately wasting your time with all the rest. Of course other things may improve power but flow is fundamental.
Of course poor exhaust design can kill an otherwise good engine. Testing your engine with a known open race design will help identify where the issue lies. Subsequently silencing the bike and maintaining HP is more difficult, but at least you would then be aware where the losses lie.
Your poor horsepower figure is probably as a result of many small things. Check the basic parameters and then if no luck get the head flow tested and do more dyno testing.
Building a fast reliable race engine is not easy and takes a lot of time and eventually experience. A tick list of settings and components will only get you so far and ultimately the engine build is more important than the performance....you need to finish to win, as they say.
Thank You so much for taking the time to make thorough reply.
Re power; This bench is set up w pretty strict parameteres so readings are conservative. This will also be mostly a parade machine so to get a good solid base set up is more important than the last hp. But we still felt this was a bit low.
Re piston; /¤./% is the correct dia, sorry. I have enclosed a picture. I know the squish is "generous", and I ordered some alu shims from You to rectify this. But my head has had some welding so the squish are is not that even or accurate so something to look at this winter. We did have to use some more timing the the figures You are qouting. I think we are at about 37 degrees now with dual plugs.
Re cam: This is a regrind on a cam I had from before. In hindsight it might have been better to buy a new one from You ;) We measured the cam at 1mm of lift and got these figures;
IO 35 degrees BTDC
IC 63 degrees ABDC
EO 76 degrees BBDC (This is the one we are concerned "bleeds" of cylinder pressure esp with the big exh valve etc)
EC 34 degrees ATDC
Lift figures measured out at 9,5mm intake and 9mm exh
I am concerned that the ports are a bit too big, but would have expected to see some of the loss come back at the top end if that was the case? Mid range, where I would have expected to see the loss seems "strong" and whitout a big dip or loss of power. I have a std small port head also but even that seems to have a really big exh port and largish exh valve. Is there a reason these were designed that way from the start? Hope to get the the head flow tested this winter as I do believe that the ports are larger than what this engine needs.
Re the exhaust; This is a downpipe from Swarbrick and then just extended to where I "needed" the muffler to be. Do You have a recommendation for a exhaust design or maker? Should we have had more of a megaphone style design before the muffler itself? Most of the designs I have seen seems to use the same dia the whole downpipe. Is this ok or should I look at having different dia to promote exh speed and pressure wave timing?
bendik
Postby bendik » Mon Sep 09, 2024 9:19 am
ALso I do have a green/white reground cam. If the ex closing timing is more correct on this one; could that actually make more hp/power than the "173" w the too early exh opening?
bendik
Postby bendik » Mon Sep 09, 2024 2:57 pm
So this is how the dyno pull looks. Would be happy to post the piccs I have of the ports if somebody would care to point out the faults ;)
Postby LaceyDucati » Mon Sep 09, 2024 9:58 pm
Bendik
I can see that this is a "race" piston, it's difficult to see the shape of the dome from the side view. The pockets look relieved at the edges which is good, but I wonder if the side of the dome is too close to the chamber. this and the large squish may explain the need for 37 degrees BTDC on a twin plug. Did you take a clay impression of the chamber on the side. You did not confirm if you measured the CR ? I've seen 250 engines perform as well on 9.5:1 as with 11:1, so piston shape can be as important than "high" CR. Looking at the power curve, my suspicion is poor flow in the head.
I can email you a sketch of a "known" race exhaust, which you could try on the dyno, that would eliminate any exhaust potential issues. Maybe you could mock up a "rough" system just for a dyno run.
The standard exhaust port is poorly shaped and too big, that said with minor cleaning up and a well shaped seat and a 36mm valve will give 30 + BHP. Trying to use a smaller valve (certainly smaller than 35mm) without filling the port will not work any better. On the inlet side 38mm can work okay if the seat, throat and port is suitably sized. However 36/38mm is an unusual/not ideal choice. The engine I described earlier in my posts, used 39/36mm valves. This also used a 34mm Mikuni, having previously used a 32mm Amal, both worked well, so it is unlikely your issue lies there particularly.
I will look at the cam figures when I have more time, what clearances did you use to obtain these figures? I have a busy week so it may be awhile.
Is the head sealing well? I ask as I can see some staining on the face, maybe insignificant, but difficult to see from pictures. Did you "blue" the head face to check contact?
bendik
Postby bendik » Tue Sep 10, 2024 1:19 pm
Thanks Nigel
I will send You an email, so You can reply to that. Looking at what You have said here and in some earlier posts I think it might be a combination of piston dome shape, too large ports/valves and the exhaust that is all working together to "rob me"
Time for a rethink and maybe start w a fresh head I think. Luckily the autumn is here already ;)
Re the piston; It is really close to the sides of the chamber, thats part of the reason the squish is conservative. I did not measure the CR, just clearances as I was trying to make it too a meet. But plenty of time for that now
Our plan was to machine the squish this winter to match the piston, as my head show signs of earlier "mangling"
I did lap the head on to the cylinder w valve grind paste. Is that how You do it, or do You have a better method?
So no rush w the answer either, do it when You have time
Thanks again
Postby Bevel bob » Thu Sep 12, 2024 7:05 am
Hi Bendik, I would very much like a photo of the port work that has been done ,and it may help others to point out any errors and help you. My head was race ported many years ago and the motor behaves in a similar way to yours with a power curve with a dip but seemingly endless revs up to 10,000 but without progression in power. It has an unknown cam with lots of overlap but low lift. As i have to run with a silencer on roads , smaller valves , ports , carb and a road cam would be a better solution. I have 3 or 4 other projects in line so am gathering parts and ideas.
bendik
Postby bendik » Sun Sep 15, 2024 7:12 pm
Bevel bob wrote:Hi Bendik, I would very much like a photo of the port work that has been done ,and it may help others to point out any errors and help you.
I will find some pictures and post for general enjoyment ;)
Postby Bevel bob » Mon Sep 16, 2024 5:15 am
My head is probably scrap due to the ill informed "tuning " that was done back then in its racing days. Yours could be the same. Its not amusing at all.
Andy Higham
Postby Andy Higham » Mon Sep 16, 2024 9:30 am
I still think your issues could be cam related.
If I am correct in my interpretation, your cam timings are :-
Inlet 35-63, duration 278 degrees, lobe angle 104 degrees
Exhaust 76-34, duration 290 degrees, lobe angle 111 degrees
Overlap 69 degrees
Lobe separation 215 degrees
The 173 cam timings are :-
Inlet 39-64, duration 283 degrees, lobe angle 102.5 degrees
Exhaust 67-38, duration 285 degrees, lobe angle 104.5 degrees
Overlap 77 degrees.
Lobe separation 207 degrees
Your cam seems very shy of overlap for a race engine
bendik
Postby bendik » Mon Sep 16, 2024 10:25 am
Andy Higham wrote:I still think your issues could be cam related.
Overlap 69 degrees
Overlap 77 degrees.
I definately think its part of the puzzle; the cam grinder offered to custom grind me a new rocker to rectify, but for £95 + postage/VAT I think I am better off saving up for a new cam from Nigel (like I should have done in the first place)
I do have a green/white cam that was ground by the same person and if the numbers on that one is better I will test that this winter to see what happens.
But looking at older posts from Nigel and Eldert I also think the ports are too big and have too low velocity
