Scrambler 350cc leaks and tightening torque
Rocla
Re: Scrambler 350cc leaks and tightening torque
Postby Rocla » Fri Dec 03, 2021 10:15 am
Thank you Duccout and Themoudie, you caught exactly my question. Maybe my english was not perfectly clear but I caught very well your answers. I will run again my bike after having tighened all the screws on the head cylinder and cylinder and check again if the bottom left side cylinder leak remains. In this case, I will go back to the meccanic (he is aware of my problem) to add some silicon just in lifting few mm the engine (without modifying the timing and dismouting everything)... I'll keep you updated
Postby themoudie » Fri Dec 03, 2021 10:40 am
Bonjour Rocla,
All the best to you and your mechanic with your efforts to make the engine oil leak free. :)
'Google' traduction.
Tout le meilleur pour vous et votre mécanicien dans vos efforts pour éliminer les fuites d'huile moteur. :)
Rocla
Postby Rocla » Fri Dec 03, 2021 11:06 am
Good french sentence (suprised it comes from Google). Well, is my english so bad?
Postby Duccout » Fri Dec 03, 2021 11:34 am
Hi Rocla,
Your English is very good, and certainly better than my French! It was clear from your first messages that you were talking about the cylinder base gasket, but somehow the message became confused as we tried to answer it, so 'well done' to Bill for bringing things back on track.
If the cylinder head bolts are tightened to the correct torque, then I think that there is a problem with the cylinder base gasket somehow, as oil leaks from this area are not normal.
Good luck,
Rocla
Postby Rocla » Fri Dec 03, 2021 12:02 pm
Thanks Colin!
Postby themoudie » Sat Dec 04, 2021 12:18 am
Bonjour Rocla,
Not at all, but I just thought it would be a little friendlier. :) And my French is awful, hence the use of the Google translator! :oops:
Rocla
Postby Rocla » Mon Dec 06, 2021 5:02 pm
Merci Bill, à bientôt :-)
Rocla
Postby Rocla » Fri Apr 01, 2022 5:56 pm
Hello everybody, my 350 Scrambler (1974) engine leaks again, at the same place, just because the O-ring gasket is not resilient enough. Who could provide me with the exact dimensions of the O -ring which is on the top of the cylinder, on the left side, positionned around the oil duct? And which kind of material it must be made of given the oil flow and temperature?
Postby themoudie » Fri Apr 01, 2022 10:53 pm
Bonjour Rocla,
May I suggest that you read the whole of this thread on this forum, as you may have the same problem?
Head/barrel_oilway_'O'_ring_thread
Puis-je vous suggérer de lire l'intégralité de ce fil sur ce forum, car vous pourriez avoir le même problème ?
Bonne santé, Bill
Rocla
Postby Rocla » Sat Apr 02, 2022 7:40 am
Many thanks again Themoudie, Up to me to find the right supplier to get such O-ring. See you soon
Users browsing this forum: No registered users and 125 guests
