125TS project - Blue smoke
veloduke
Re: 125TS project - Blue smoke
Postby veloduke » Mon Jul 06, 2020 6:53 pm
This place sells Duke stuff;
http://recambiousado.com/venta/index.php
Has a lot of 125TS/S stuff. You just need google translate :) .
I bought valves and guides from him, piston from classicducati.co.uk., and rocker pins from either Lacey Ducati or classicducati.com.
Pins were 8mm from a 450.
Hope this helps.
Max
Maca71
Postby Maca71 » Mon Jul 06, 2020 8:23 pm
Thanks chaps
Further update. Someone suggested that a blocked breather might be a simple cause. Funnily enough the cap was not on correctly.
Cleaned it up and refitted correctly, and whilst the problem still exists, the amount of blue smoke is reduced.
I have ordered the valve guides from Guzman, but having read the valve guide replacement thread a little spooked that it may be beyond my capabilities. These guides need reaming after firmest as well.
Is there anyone recommended who I can send my head and valve guides to who can install for me?
Max
Postby Duccout » Mon Jul 06, 2020 8:50 pm
We need to know where you are! In the UK? Then Lacey Ducati is the obvious choice.
Maca71
Postby Maca71 » Mon Jul 06, 2020 9:14 pm
Yep UK
Milton Keynes.
Maca71
Postby Maca71 » Tue Jul 07, 2020 7:51 am
Compression reading taken today. 95psi
I am told fairly healthy.
