What is the best charging and ignition system for wide case 450
Re: What is the best charging and ignition system for wide case 450
Postby graeme » Wed Jul 15, 2020 7:46 am
Or for a 450 half a degree retarded to save your ankle
I have Sachse on my RT set at 1/2 degree retarded, starts fine with no kick back.
Postby Duccout » Wed Jul 15, 2020 10:06 am
Here is a question: why is the 450 engine timed to 28° BTDC, but the early 860/900 engines (with identical cylinder heads to the 450) were timed to 35°? Strangely, with the introduction of the Darmah, Ducati retarded the timing to 32°, and later, with the very last 900 engines (still with the same piston/combustion chamber) they retarded it further to 28°.
Postby Ventodue » Wed Jul 15, 2020 11:01 am
graeme wrote:Or for a 450 half a degree retarded to save your ankle
:D . You know, Graeme, I've only once had my SCR kick back - and that was my fault, for not kicking it like I meant it ...
Lucky, eh?
Postby Ventodue » Wed Jul 15, 2020 11:05 am
Duccout wrote:Here is a question: why is the 450 engine timed to 28° BTDC, but the early 860/900 engines (with identical cylinder heads to the 450) were timed to 35°? Strangely, with the introduction of the Darmah, Ducati retarded the timing to 32°, and later, with the very last 900 engines (still with the same piston/combustion chamber) the retarded it further to 28°.
Mystery .. different valve timings? Dunno. Definitely one for the engine designers, Colin.
HMBAtrail
Postby HMBAtrail » Thu Jul 16, 2020 8:41 pm
Duccout wrote:but the early 860/900 engines (with identical cylinder heads to the 450) .
Huh?
Postby Duccout » Fri Jul 17, 2020 7:44 am
!!! Same valves, same combustion chamber, same piston shape.....Different ignition timing.
Postby graeme » Fri Jul 17, 2020 7:46 am
Perhaps saving the big ends from pre ignition and damage ?
Postby Duccout » Fri Jul 17, 2020 9:01 am
Definitely true that an advanced ignition timing gives the bottom end a harder time.
DBDBrian
Postby DBDBrian » Fri Jul 17, 2020 9:31 am
Duccout wrote:!!! Same valves, same combustion chamber, same piston shape.....Different ignition timing.
Are the connecting rods a different length ?
Brian
Made in England
Postby Duccout » Fri Jul 17, 2020 10:30 am
Probably - 450: 75mm stroke, 860:74.4mm stroke.
Users browsing this forum: No registered users and 210 guests
