Is it charging??
howlndog
Re: Is it charging??
Postby howlndog » Mon Mar 19, 2018 8:32 pm
I've used one of these in an old car and it has worked perfectly. It's super small and easy to program and install.
https://www.ebay.com/itm/6v-12v-24v-Programmable-LED-Battery-level-voltage-monitor-meter-indicator-J/200843083721?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
Derek
'70 350 Mark 3D
Postby Bevel bob » Mon Mar 19, 2018 9:22 pm
I have considered one of those , the only downsides are they use current all the time and are a little on the big side.
Postby Jordan » Mon Mar 19, 2018 9:44 pm
ducwiz wrote:But, after all, what is "a simple indicator lamp", how/where you would connect it, and what would it finally indicate?
A charge indicator light is a basic warning device that warns if you are likely to experience a flat battery in the near future while using your vehicle.
Another benefit is that it lets you know the ignition is switched on with engine not running.
I'm not sure of the best way to have one on a standard Ducati single.
My 12V conversion uses a rectifier-regulator from a small tractor, with includes an output wire for a charge indicator lamp. Cheap and nice!
Postby Jordan » Mon Mar 19, 2018 9:46 pm
howlndog wrote:Image
I have something like that on one of my bikes.
I can't use all of its functions, because I'm red-green colour-blind.
Far too complicated. :)
