The factory manual describes some tests for the stator and rotor of 40W alternators.
Rotor test involves spinning it to 3000 rpm.
Just an idea: Temporarily rig up a Kettering system (battery/coil) to provide sparks so you can run your engine to do the tests?
Week spark on magneto bike
Nick
Re: Week spark on magneto bike
Ditch the stock ignition coil and swap for a later Japanese bike coil from a magneto bike. (Or a at least wire one up and see if there's a difference.)
The magnetism in my MKIII flywheel was weak, so I got it re-magnetized. Don't know who can do that now.
Also, make sure you've got either a fixed (non-advance) points cam, or the proper one for the magneto engine.) The dwell is very different for the battery models.
Put a Mikuni on it!
Moto Chuck
Nick wrote:Ditch the stock ignition coil and swap for a later Japanese bike coil from a magneto bike. (Or a at least wire one up and see if there's a difference.)
Have been too busy to work on the bike lately but am trying to get back to it.
I do know where there is a remagnetizer for the Ducati single mag buckets but that will require taking off the left side of the engine. Don't want to try that till I have exhausted the other possible causes.
My 1967 has a point cam with an advance built in.
As I said earlier, the bike ran well when I put it away back in the day. This is not a bike that has had unknown parts and pieces cobbled together that I don't know about.
dsmess
You might try temporarily grounding the alternator white wire. Make sure you have a low resistance connection to the engine case. This will eliminate the stoplite and bypass switch wiring. The stock coil should work, but a Honda C100 AC coil is better.
Dave M.
Dave M.
