Oil Way
kmev
Re: Oil Way
If only the seat is leaking, why is it burning oil? Shouldn't burn oil unless the guide is loose or the stem seal torn. As the head if off already, I would also take a close look at your compression rings.
frankfast
Re: Oil Way
Right. The bike doesn't smoke when running although the plug was blackened and I do see a little oil on the spark plug after kicking it over. Since the piston and rings are new, although installed a while ago, they may have not had enough time to seat. The guides and valve seals are also new but the valves are original. There wasn't any slop when I installed them in the new guides. It's probably wise to install new valves if I am going through the trouble of getting the seats refurbished.
Users browsing this forum: Google [Bot] and 79 guests
