left threaded plug in fork lower sliding tube
Re: left threaded plug in fork lower sliding tube
Postby double diamond » Wed May 13, 2015 8:43 pm
If you're satisfied that they're clean, no need to remove. The retaining clip can be extremely difficult to remove, usually requires grinding a notch in the tube to get under the clip in order to remove it. Matt
narrow_monza
Postby narrow_monza » Thu May 14, 2015 2:53 am
double diamond wrote:If you're satisfied that they're clean, no need to remove. The retaining clip can be extremely difficult to remove, usually requires grinding a notch in the tube to get under the clip in order to remove it. Matt
They look clean. Are they supposed to be free to jiggle or wedged?
Postby double diamond » Thu May 14, 2015 4:34 pm
The balls should be free to move in the valve. On compression, the balls are forced out of the ports by the damping oil and offer little compression damping. On rebound, the balls block the ports and most of the damping oil is routed through the damper rod to effect some rebound damping. Matt
narrow_monza
Postby narrow_monza » Thu May 14, 2015 10:08 pm
Thanks Matt!
-Adrian
