Adrian
Some notes and spacer measurements were included with your parts.
Narrow Case kick start repair revisited.
narrow_monza
Re: Narrow Case kick start repair revisited.
Hi Nigel,
I better go dig out the box.
Thanks!
-Adrian
Thanks!
-Adrian
If you can't find them I will email them to you.
blaat!
After getting frustrated with my kick start slipping, I ripped the engine back apart. I was thinking about adding the spring bridge, but then I saw that I would need to drill a hole in the case and chickened out. I figured I would try to find an alternative way to improve the spring return so started looking closely for ways to do that. Then I noticed... strangely enough... there is already a hole there for the bridge! At least I think that is what it is:
I put a screw in the threads and it is an M7.
I noticed that Nigel appears to be out of stock on the bridges. Is there anywhere else to acquire one along with the associated parts?
blaat!
Found it. Just needed to do a little online searching.
