By: Eldert...
" there is something odd about the timing figures .
on my degree wheel it goes from zero to 90 degrees and then back to zero again "
____ Eldert, could you please elaborate on exactly whatever in particular you're actually meaning to refer to ? ...
As you've left your post-wording, I'm led to assume that you're possibly referring to the inconsistent v.timing-figures stated for the Lento-version, as the figures stated within the Lento-version's crankshaft/cam-timing depiction don't all exactly match-up with those listed, (as seen listed below the corresponding depiction). ...
While the crank/cam-timing depiction for the Rapido-version and IT's corresponding listing below, actually both do have PROPERLY matched-up figures,, it seems somewhat obvious that the depiction for the Lento-version was borrowed-over from the Rapido's, and was quite very poorly adapted to also properly reflect the actual figure-representations for the Lento-version, (and thus the Lento-version's depiction-figures don't all properly correspond with the associated listed-figures). _ Therefore I don't trust all the figures stated within the Lento-version's depiction, however I do believe that the stated-figures in the listing (below the Lento's depiction) are correct.
__ Despite that outwardly blatant published-error, I'm thinking that Eldert's concerned-issue is probably about something-else still.
So hopefully he will get whatever his particular presented-issue cleared-up sometime soon.
Vento 350
Re: Vento 350
Re: Vento 350
Just in case a bit of translation helps
RAPIDO (orange and white)
Inlet
Opens at 72° before TDC
Closes at 100° after BDC
Exhaust
Opens at 98° before BDC
Closes at 80° after TDC
LENTO (grey)
Inlet
Opens at 68° before TDC
Closes at 95° after BDC
Exhaust
Opens at 84° before BDC
Closes at 78° after TDC
(PMS = Punto muerto superior = Top Dead Centre. PMI = Punto muerto inferior = Bottom Dead Centre)
These specs come from the owner's handbook. And are confirmed in "Ducati (Mototrans) much más que una licencia de fabricación" by Francisco Herreros. However, I don't know what the measurement clearance is. But I believe it's normally 1mm for Ducatis - ?
Btw, Muzz: Jon Peglar is very knowledgeable on the Mototrans bikes - much more than me! He's on this Forum from time to time.
Feliz navidad!
Inlet
Exhaust
LENTO (grey)
Inlet
Exhaust
Feliz navidad!
Re: Vento 350
DewCatTea-Bob wrote: ... as the figures stated within the Lento-version's crankshaft/cam-timing depiction don't all exactly match-up with those listed ..
Ha! Hadn't noticed that! You've got sharp eyes there, Bob ...
Re: Vento 350
Hi Bob,
Would I be right in thinking that, given the fact that for 7 out of the 8 cam angles there is no more than 5°difference, the best way to tell the which cam is which would be to measure the opening of the exhaust valve? Because there there is a (notional) difference of 14° - ?
Un saludo
Un saludo
Re: Vento 350
" These specs come from the owner's handbook. "
____ Thanks for independently listing those stated v.timing-figures Craig, as I was thinking of doing the same myself (since those you had copy-posted were not very clearly copy-printed).
If I had gotten to that task before you did, I was also going to list the equivalent figures for the two Green & White camshafts, as well, (for comparison).
" I don't know what the measurement clearance is. But I believe it's normally 1mm for Ducatis - ? "
____ NO... I believe the 1mm-standard lift starting-point is a Japanese-set standard, (which is not a FAIR method for determining a camshaft's ACTUAL valve-timing !).
Where-as Ducati's method of measuring their cam's v.timng is done the fair way. ...
Ducati FAIRLY takes-out MERELY the individual camshaft's particular 'clearance-ramp' (which precedes the lift-ramp), away-from the measurement-reading, so as to then measure JUST the cam-lobe's actual INTENDED-lift only.
And-so since many of Ducati's camshaft-models have differing clearance-ramps, each individual camshaft-model is thus-then supposed to have it's v.timing measured with the valve-clearance reset to some individually given factory-setting, so as to then fairly measure the v.timing of a particular cam-model (without also unfairly getting the clearance-ramp mixed-up into the measurement-reading).
The Jap.method gets-around the complication of varied clearance-ramps, by just simply allowing an even 1mm to absorb whatever the clearance-ramp may be on any particular cam, (thus unfairly also absorbing some unknown portion of the actual lift-ramp of a cam-lobe as well).
__ I don't know what the valve-clearance is supposed to be reset to (so as to avoid including the clearance-ramp into the measurement-reading of the actual lift-ramp), for the cam-versions of the Vento camshaft-models. _ However I'd most suspect that the factory-recommended clearance-settings would be close to, (if not the very same as) that recommended for the G&W.camshafts.
____ Also, I note that you've stated that the color-code of the camshaft for the Rapido-version is "orange and white", and the Lento-version's is "grey" ...
I can't confirm whether the orange&white code is correct or not (for the Rapido-cam), but, the Lento-version's cam.color-code can't be "grey" because, 'gray' is the color-code for the Mach-I camshaft (which is too widely different to share a color-code with).
__ Where did you learn-of those supposed color-codes from ?
Could it be that rather than "grey", the Lento-cam's color-code may be 'gray & white' ? _ Or even perhaps ALSO orange&white, since the two Vento cam.versions are so similar,, cuz Ducati has already before used an identical color-code for two other camshafts that were similarly varied - (that being the green&white color-code designated for both the 250F1 & the 350M3 camshaft-models).
__ For comparison, here are the v.timing-figures for the two G&W.cams...
INtake - opens BTDC / closes ABDC _ EXhaust - opens BBDC / closes ATDC
'250-F1' cam = 70BT / 84AB _____________________ 80BB / 64AT
'350M3' cam = 65BT / 76AB _____________________ 80BB / 50AT
DUCATIly,
DUCATIly,
Re: Vento 350
DewCatTea-Bob wrote: NO... I believe the 1mm-standard lift starting-point is a Japanese-set standard ...
Ah, interesting ("Me, I know nuttin'"..
http://www.ducati-upnorth.com/tech/camtiming.php
Re: Vento 350
____ Right, good reasoning ! _ And since Ducati allows a +/- 5-degree tolerance in their actual camshaft v.timing-figures, your point becomes quite significant to discern the Rapido & Lento cam.versions apart from one another, as there may thus-then possibly be only-just 4-degrees difference between the two differing cam.versions at that ex.valve opening-point.Ventodue wrote:Would I be right in thinking that, given the fact that for 7 out of the 8 cam angles there is no more than 5°difference, the best way to tell the which cam is which would be to measure the opening of the exhaust valve? Because there there is a (notional) difference of 14° - ?
" I got the 1mm reference from here, "
____ I suppose that by THESE-days, (sometime since Ducati abandoned their tower bevel-gears, for belts), Ducati ALSO may have converted-over to that (possibly now world-standard), 1mm-standard lift-point (began by the Japanese).
Which if so, would be a shame since that imprecise method compromises fair comparison of differing v.timing-specs (between various camshafts' ACTUAL valve-timing).
Re: Vento 350
Ta Bob - good stuff.
As to ...
They're the codes given in the owner's manual and also in the Herreros book (which may just be copying an error in the manual, of course
). But I'd hazard a bet that, even tho' the Mach 1 had used a gray-coded cam, Mototrans felt themselves sufficiently distanced in time and space to use the same color ...
P.s Just done a bit more looking. Here are the specs from the parts book (bottom left):
This is the same spec that the owner's manual gives for the Rapido cam. And down below I see it reads:
"Regulación de control entre válvula y balancín 0,1mm"
Pps. Thought you might like to see this too, Bob - same source, i.e the parts manual.
Un saludo
As to ...
DewCatTea-Bob wrote:Also, I note that you've stated that the color-code of the camshaft for the Rapido-version is "orange and white", and the Lento-version's is "grey" ...
<snip>. Where did you learn-of those supposed color-codes from ?
Un saludo
The Gray/(grey) Camshaft Color-code
____ Thanks for another informative post, Craig !
" They're the codes given in the owner's manual and also in the Herreros book . But I'd hazard a bet that, even tho' the Mach 1 had used a gray-coded cam, Mototrans felt themselves sufficiently distanced in time and space to use the same color ... "
____ That's really too bad, darn-it ! ...
Cuz Ducati has already used the gray-code for two other camshaft-models ! - The Mach-I & the WideCase Mark-3 Duke-models.
__ For comparison, here follows the two Gray-coded cam-v.timing figures...
___ INtake - opens BTDC / closes ABDC ___ EXhaust - opens BBDC / closes ATDC
The 'Mach-I' cam = 62BT / 76AB _______________________ 70BB / 48AT
'250M3' w-c.cam = 60BT / 70AB _______________________ 70BB / 50AT
(Side-NOTE: The pre-1965/n-c.Mark-III camshaft's color-code is 'Red', while the post-1964/n-c.Mark-3 employed the Gray/M1.cam .
Also, I have already added the figures for the two Green&White cam.models, two self-posts prior/back.)
____ IF the normal running-v.clearance is supposed to be near .002", THEN the resetting of the valve-clearance to ".1mm", (as you seem to have found & posted), for the particular-purpose of measuring the camshaft's v.timing, seems to be a reasonable amount of set-clearance for bypassing the expected clearance-ramp and-yet still catch pretty-much all of the cam-lobe's entire intended 'lift' .
However I really don't read Spanish too well, and-so I could just as well expect that that stated ".1mm" may actually be the intended 'running-clearance' for the normal operation of the valves, (in which case, .2mm may then be more like the needed clearance required to check the actual cam.valve-timing).
Re: Vento 350
Is it possible to work out how much cam timing clearance should be used, if you didn't know?
For example, could an abrupt change in contour signify the "real" opening point?
