Clutch Housing nut reverse threaded?
Re: Clutch Housing nut reverse threaded?
Postby JimF » Sat Sep 29, 2012 3:59 pm
There wasn't a tab washer in there when I took it apart, and I put it back together without one.
If I leave it "as is", what will be the givaway that the clutch nut has come loose?
Is it a catastrophic failure if it comes off, or just the inconvenience?
Is it the same part for narrowcases as widecases?
Postby DewCatTea-Bob » Sat Sep 29, 2012 7:24 pm
" If I leave it "as is", what will be the givaway that the clutch nut has come loose? "
____ When it first comes-loose, you'll notice that the clutch hand-lever's adjusted slop will vary depending on whether the engine is accelerating the rear-wheel (opened throttle), or the rear-wheel is forcing the engine to turn (closed throttle).
" Is it a catastrophic failure if it comes off, or just the inconvenience? "
____ When the nut becomes THAT loose, then the clutch-plate set will not be able to be disengaged,, and when attempting to do so, the whole clutch will then be forced outward & against the inside of the primary-cover, (which of-course is a bad-thing).
" Is it the same part for narrowcases as widecases? "
____ Yes, same "tab washer",, (but you could make your own ['lock-plate'] which would work much better).
Postby Ventodue » Sun Sep 30, 2012 5:11 pm
Btw, Jim, I have now found a torque setting reference. It's in the Clymer manual which I think - and correct me, someone, if I'm wrong ;) - was basically a re-print of the narrow-case factory workshop manual :?:
Anyway, in the Clymer, it says, 700-850 ft/lbs (it's at the top of page 57 in my version).
Ciao
Postby Ventodue » Sun Sep 30, 2012 5:24 pm
DewCatTea-Bob wrote:" Is it the same part for narrowcases as widecases? "
And here he is, Jim ... ;)
Postby DewCatTea-Bob » Sun Sep 30, 2012 10:46 pm
____ Firstly, thanks Craig, for being one of our members who wish to bother themselves to help-out here at this w.site !
" in the Clymer, it says, 700-850 ft/lbs (it's at the top of page 57 in my version). "
____ Of-course that can't be right... I'm now not where I have one of those manuals to check-out for myself but, it seems that either SOMEone has left-out a decimal-point, or possibly had actually meant 'cm/kg' (rather than "ft/lbs") !
Cuz I could far-more easily believe 50.5 to 85 foot/pounds, for that clutch-nut.
Postby Ventodue » Mon Oct 01, 2012 9:18 am
DewCatTea-Bob wrote:" in the Clymer, it says, 700-850 ft/lbs (it's at the top of page 57 in my version). "
Ta, Bob - no, it can't :oops:. Should have seen it, but that will teach me to believe anything I read in a Clymer ...
And that's got me thinking about the earlier value I gave Jim for a standard 16mm nut. Even though I got it from what is claimed to be the ISO table * ...
... it has to be a load of tosh. Sorry, Jim :oops: :oops: :o . I'll go edit my earlier posting.
* ISO 898-1:2009, "Mechanical properties of fasteners made of carbon steel and alloy steel. Bolts, screws and studs with specified property classes. Coarse thread and fine pitch thread."
Ciao
DanM
Postby DanM » Mon Oct 01, 2012 2:16 pm
The chart is in Newton Meters. 218 Nm = 161 Ft Lb
Postby Ventodue » Mon Oct 01, 2012 2:38 pm
DanM wrote:The chart is in Newton Meters. 218 Nm = 161 Ft Lb
Sure is, Dan. And that's the figure I gave Jim ... and can't be right, surely ?
DesmoDog
Postby DesmoDog » Sat Oct 06, 2012 12:34 pm
In any case, be sure to heed the factory's warning to NOT USE the kickstart shaft as a brace for the tool you use to lock the clutch housing in position so you can remove the nut. The warning is easy to miss in the service manual (well, it was easy for me to miss apparently).
This is the result of trying to use that shaft to brace the tool:
Note the shiny area where the kickstart shaft boss used to be.
Don't be a maroon like me, pay attention to the small print in the manual... that little "oops" was a four year long gumption trap on my 160 project.
Postby JimF » Sun Oct 14, 2012 7:58 pm
Thanks Howard,
I received your locking tabs and installed the first one yesterday - perfect fit - easy to use.
They can be had at:
www.discovolantemoto.co.uk
