Connecting Rod Dimensions
Pete
More tech data from the past. Enjoy!
Re: Connecting Rod Dimensions
" More tech data from the past. Enjoy! "
____ Where did you get all this data Pete?
__ Where it's listed: "160,175/250" , shouldn't it read '175,200/250' instead? _ Cuz I don't recall the 160-rod being that same 125mm size. - ([Hey Eldert, could you confirm the specs for the 160-rod?])
__ Also, this chart omits the specs for the narrow-case 350-rod -(= n-c.250), and also that for the post '72 450-rod.
__ Very nice of you however, to have bothered to post this data which you do have, of course!!
Pete
This is another page from the 1987 Eurosport catalog. If you look back in the DIOC newsletters, you can see more stuff from Eurosport. The catalog is a unique mix of parts for sale and tech info. Now if only I could find parts at those 1987 prices.
Pete
Pete
i have the same Eurosport catalog printed on yellow paper
i dont have any 160 cc stuff laying around to confirm specs .
however the late type widecase conrod is not on this list
that rod ( called the B type ) was there in 250/350 and 450 lenghts
measuremends are bigendpin is 32 / 35 / 32
the rod bearing is also wider at 22 mm . the bearing is 35 / 43 / 22 mm and had double row needles
this bearing is no longer available but a Yamaha rodbearing part nr. 93310 - 635 - C6 will fit
Pete
Hi Eldert,
That is the same catalog on yellow paper. Thanks for the additional information.
Pete
Pete
