Fire went out!
mrkprsn
Re: Fire went out!
Postby mrkprsn » Wed Mar 18, 2026 12:50 pm
One other thing. Do you use a velocity stack or hose connected to a side cover? i had an issue where my bike would bog at higher RPMs. My carb hose had a slight restriction in it before it opened up. Once I cut the restricting piece out of the hose the bike ran fine.
Romomoto
Re: Fire went out!
Postby Romomoto » Wed Mar 18, 2026 3:00 pm
Roland, I'll get a photo today.
The only thing I have replaces is the three wires from the stator.
Roland
Re: Fire went out!
Postby Roland » Wed Mar 18, 2026 3:15 pm
very appreciated, thanks!
replacing wires will be my next job, i guess...
350 Scrambler, 1973
Romomoto
Re: Fire went out!
Postby Romomoto » Wed Mar 18, 2026 6:09 pm
Roland, here's a photo of my stator. You can't tell which connection is for which circuit, but I'll also attach the wiring diagram that shows the order.
Also - anyone know where the cylindrical piece belongs in the other photo? I found it on my table under the disassembled primary but don't see any place it might fit. Maybe from a previous job?
One more question for the collective intelligence: the AC coil's terminals are marked 1 and 15. Wiring diagram does not specify which side is to be grounded. Should I assume that since it's an AC system it does not matter which?
Romomoto
Re: Fire went out!
Postby Romomoto » Wed Mar 18, 2026 6:12 pm
Mrkprsn: I have a conical K&N-type air filter attached. It's wide open inside.
Re: Fire went out!
Postby graeme » Wed Mar 18, 2026 8:10 pm
The cylindrical piece looks like a piece from the clutch push rod assembly
Romomoto
Re: Fire went out!
Postby Romomoto » Wed Mar 18, 2026 9:43 pm
That would make sense. Looks like a small ball in that channel, which is what I saw when I pulled the clutch down. But perhaps it dropped out while I was looking the other way!
Roland
Re: Fire went out!
Postby Roland » Thu Mar 19, 2026 6:40 am
Good morning and thanks for the photos!
Stator and wiring looking good.
Comments on schematic:
There may be induced a lot of trouble by this "safety setup" combined ignition/brake wiring.
Never seen before...
Check this again, and in doubt replace by interim wiring for testing.
For the HV-coil:
Left is 1, right is 15.
You see it by understanding this common point for both windings.
350 Scrambler, 1973
Romomoto
Re: Fire went out!
Postby Romomoto » Thu Mar 19, 2026 12:48 pm
Roland, yes - wiring the bike so that the ignition quits if/when the brake light filament fails is...uniquely Italian, I suppose. From what I've read, many or most of the bikes wired this way have a toggle switch wired in near the taillight (typically on the housing itself) that will bypass the filament.
Mine doesn't have such a switch but it seems to me that in the case of brake light failure I could just cross the two wires at the brake switch and achieve the same thing. (Or carry extra bulbs).
As I recall, my BMW R100 had a similar wiring anomaly, not involving the brake light but one of the lights up front. I think I dealt with that by wiring in a resister or small bulb in parallel. Long time ago, and my memory fades.
Thanks for the tip on the coil wiring. I had not noticed the primary/secondary connection you pointed out.
Bob
