1970's Dunlop "Wobble and Weave" film link
Postby themoudie » Fri May 19, 2023 10:11 am
So, where is the Ducati representation in this wee film and has anybody ever experienced these events whilst riding a Ducati single, or twin?
Even when using a Dunlop TT100 on the front and an Avon RoadRunner on the rear of the 450, I never had these issues. Maybe I wasn't trying hard enough? ;)
Re: 1970's Dunlop "Wobble and Weave" film link
Postby Duccout » Fri May 19, 2023 11:45 am
Thanks for posting that Bill, very interesting. I have experienced wobble on my big Ducatis - on my 750 Sport when loaded up with masses of camping gear etc, the handlebars would wobble alarmingly at low speed, constantly, until speed went above 40 MPH, and I'm assuming that it was due to the weight being concentrated over the back wheel. My 900S2 though wobbled all the time from new, and the issues with the model were so well-known that the TUV in Germany were talking of banning it and were experimenting with frame strengthening struts. It was nothing to do with the frame though; the S2 is a very heavy bike and over the years I gradually removed weight by changing fairing, mudguards, exhaust, battery etc until I took off about 50 LBS, and the wobble disappeared.
I think that it was due to the fact that Ducati did not increase the spring rate for the S2 from the much lighter SS, in spite of the massive amount of extra weight. As for the high-speed weave shown in the film, I have never experienced that, and neither would I like to! It would seem that it is induced by the rider sitting up and so transferring the weight rearward....
Postby blethermaskite » Fri May 19, 2023 5:58 pm
Very interesting subject.......I will try not to drone on too much....but.....for most of the ownership of my 74 350 Mk3 (until about 15 years ago) It has had a real and sometimes quite dangerous tendency to front wheel wobble at speed/potential to tank slappers, but all only under very particular circumstances........at speed (70mph or over) on a rising road at the apex of a sharp left or right hand corner when the front end would get a little light off it would go. I tried everything I knew to fix this all to no avail .......tyre pressures, different tyres, fork oils of all weights, different preload on forks, variably dropping the forks through the yokes, wheel alignment, swopping from the odd 19" front wheel rim to a normal 18"(the wheel size change helped a little but didn't cure it).
In every other respect the bike has handled flawlessly and has been (and still is my favourite motorcycle of all time) so I kinda gave up and fitted an hydraulic steering damper which obviously didn't fix the problem .....but like a painkiller tablet it hid it from me. About 15 years ago at an autojumble in Dublin I couldn't believe my luck when for very little money I managed to buy a set of genuine Ceriani 35mm grand Prix road racing forks (and I mean real ones not repro) these were almost unused and had been removed from an American import Triumph flat tracker.
I stripped them, cleaned them, fitted new seals, and put them on the front of my 350.......the overall general improvement was so noticeable that I tried removing the hydraulic steering damper......and guess what the wobble/tank slapper was gone never to return! :D at any speed or circumstance, I without doubt spent a bloody fortune on sets of tyres to cure my wobble and it was the cr*p Marzzochi forks all along.
P.S. My 250 desmo has never exhibited this problem!
Postby Bevel bob » Sat May 20, 2023 4:42 am
I have only ever experienced that with a rear wheel puncture . Never on a Ducati or a Norton featherbed (even when fitted with heavy panniers /fairing/ passenger ). Not even on a 1930's sports 500. Put those iffy bikes in a skip !!.
Users browsing this forum: Google [Bot] and 82 guests
