Best way to clean discoloured exhaust header?
cooperplace
Postby cooperplace » Tue Feb 14, 2023 12:45 pm
Someone suggested steel wool, but after seeing v little return for a lot of elbow grease, I'm looking for something easier. thanks
be nice, I'm not very bright.
Re: Best way to clean discoloured exhaust header?
Postby themoudie » Tue Feb 14, 2023 2:58 pm
Chrome plate or stainless steel pipe?
BillR
Dave354
Postby Dave354 » Tue Feb 14, 2023 4:54 pm
Hi, in what way has it discoloured? Just bluing from heat or corrosion, dirt etc?
Dave
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Postby blethermaskite » Tue Feb 14, 2023 5:39 pm
If it has blued? the only thing that will improve the look is solvol autosol which will take the bad look of the blue by polishing the chrome again but will not remove the colour very much......just a little.
cooperplace
Postby cooperplace » Wed Feb 15, 2023 10:49 pm
Dave354 wrote:Hi, in what way has it discoloured? Just bluing from heat or corrosion, dirt etc?
Dave
It's a chrome plate pipe, and it looks like some fluid and dirt has hit it while hot and baked on. Maybe ridden thru a puddle while hot.
Dave354
Postby Dave354 » Wed Feb 15, 2023 11:00 pm
https://youtu.be/tWL6PGx7HZY
This certainly works on stainless.. worth a try?
Triumph Tiger 1200
Cornwall, UK
cooperplace
Postby cooperplace » Sat Feb 18, 2023 12:10 pm
thanks, but alas Harpic don't sell the 11% HCl toilet cleaner in Australia. The only one with acid (most are caustic) is 2% lactic acid. I gave it go and it did nothing. All is not lost tho' because it works well in the dunny.
Site Admin
Postby JimF » Sun Feb 19, 2023 11:36 pm
https://blue-job.com/
I used this on a chrome header that turned blue up where the header entered the cylinder head.
It worked to my satisfaction. It left the chrome looking a little yellowed, but the deep blue hue was gone and I was happier to have the less noticeable yellow tinge than the deep blue color.
Users browsing this forum: Boxprod and 172 guests
