Mikuni VM24
Re: Mikuni VM24
Postby Duccout » Tue Mar 22, 2022 9:28 am
I have to agree with George. You do not know what your engine is, so it could be a Sebring or Mk 3 or Scrambler, and the carb size will depend on what state of tune the engine is in and how you are going to use it. I would think that a 28mm would be a good choice for a Sebring for gentle use, a 30mm for Mk 3 or Scrambler for something a bit more go and for outright power a 32mm. A 24mm is very small for a 350.
Mark3Cam
Re: Mikuni VM24
Postby Mark3Cam » Tue Mar 22, 2022 10:56 pm
Duccout wrote:I have to agree with George. You do not know what your engine is, so it could be a Sebring or Mk 3 or Scrambler, and the carb size will depend on what state of tune the engine is in and how you are going to use it. I would think that a 28mm would be a good choice for a Sebring for gentle use, a 30mm for Mk 3 or Scrambler for something a bit more go and for outright power a 32mm. A 24mm is very small for a 350.
Really appreciate all the input, shame I ordered a rebuild kit for the VM 24 already. Yeah the frame numbers lined the bike up with likely being a 68 Mark 3 but the engine numbers make it a 72 350 and I guess not much to go as to what that would have come out of. Regardless all signs point to a VM30 to save myself some grief! On the upside it will save me rebuilding a carb ;)
Mark3Cam
Re: Mikuni VM24
Postby Mark3Cam » Wed Mar 23, 2022 2:51 am
Thanks for the advice boys - have a VM30 on the way
Re: Mikuni VM24
Postby LaceyDucati » Wed Mar 23, 2022 6:46 am
You don't say which model your 350 is, I suspect it is a narrowcase 350 if someone has fitted a VM24mm. The original carb on a 350 Sebring is a Dellorto UB24BS and the VM24 would be a suitable replacement for original if you only require original performance. The Sebring has a small inlet port and a 28 or 30mm carb will be to large without modification to the porting. The Sebring is a "cooking" model and the performance will be fine for it's needs on a 24mm carb. Carb size will depend on model, port size and desired performance and use.
Re: Mikuni VM24
Postby George » Wed Mar 23, 2022 9:30 pm
Would not the full engine number give you an idea of model and year. I have some info in Ian Falloon's book of overhead camshaft singles. Can never be sure head is original but measuring diameter of inlet tract will give you maximum carb size.
George S Norfolk UK
Mark3Cam
Re: Mikuni VM24
Postby Mark3Cam » Thu Mar 24, 2022 1:27 am
LaceyDucati wrote:You don't say which model your 350 is, I suspect it is a narrowcase 350 if someone has fitted a VM24mm. The original carb on a 350 Sebring is a Dellorto UB24BS and the VM24 would be a suitable replacement for original if you only require original performance. The Sebring has a small inlet port and a 28 or 30mm carb will be to large without modification to the porting. The Sebring is a "cooking" model and the performance will be fine for it's needs on a 24mm carb. Carb size will depend on model, port size and desired performance and use.
Engine was identified on here as a widecase and the gland nut suggested it was a ‘72.
Inlet is 30mm but by the time I factor wall thickness on neck of spigot on the Mikuni It measures out to a hair under 32mm so a VM30 should work….here’s some pictures of the engine for those that hadn’t seen it, along with number.
Mark3Cam
Re: Mikuni VM24
Postby Mark3Cam » Thu Mar 24, 2022 1:34 am
Here’s where my bike and it’s numbers fit in the list, from my first inquiries into figuring out what I had. My frame remains a mystery….
My bike is the first one listed in red
The engine model stamp was mostly ground off but was able to read a 350 in there faintly
Re: Mikuni VM24
Postby ducwiz » Thu Mar 24, 2022 6:31 pm
If "gland nut" denotes the feedthrough for the alternator cable, this engine should be idntified as a '73/74 model. This type of gland nut, the large brass or bronze version with a single hole-rubber grommet , was used with the Motoplat alternator/ignition systems. Ducati sytems used the same nut, but a dual-hole grommet. The cases for the earlier alternator used with the points ignition came with a nut with smaller thread, and made of black bakelite.
Refer to parts catalog:
Re: Mikuni VM24
Postby LaceyDucati » Thu Mar 24, 2022 7:31 pm
It wasn't obvious from the post that this was a W/C. It's obviously from these pictures it's W/C probably circa 1973 and a 24mm carb is too small relative to the port size. A strange choice of carb for the previous owner.
The port has obviously been modified in some way if it is close to 32mm. The largest standard port on a spring valve W/C single is 29mm. As you say a 30mm carb should work OK.
Re: Mikuni VM24
Postby Jordan » Thu Mar 24, 2022 8:43 pm
ducwiz wrote: The cases for the earlier alternator used with the points ignition came with a nut with smaller thread, and made of black bakelite.
It might be worth noting that a Motoplat CDI type alternator also can be used with the smaller type gland nut/crankcase.
Users browsing this forum: No registered users and 179 guests
