Postby Jon Pegler » Sun Mar 06, 2022 1:36 pm
Hi Peter,
Classic Transfers in the UK produce a vinyl Ducati and a Vento adhesive in the font you require.
They also make the 'Made in Spain DUCATI Made in Spain ' adhesive for the wheel rims if you need them.
Postby Ventodue » Sun Mar 06, 2022 2:35 pm
And that is thanks to Jon - he's too modest to say it himself.
https://classictransfers.co.uk/product/ ... -178x24mm/
cooperplace
Postby cooperplace » Mon Mar 07, 2022 7:11 am
Thank you, that is wonderful. Too good to be true!
be nice, I'm not very bright.
Postby themoudie » Mon Mar 07, 2022 8:36 pm
Excellent quality water slide transfers, that are relatively easy to apply and don't react to the lacquers used these days. DO READ THE INSTRUCTIONS SUPPLIED!
Being a Philistine I used a REF: 0077 on the tank of my '74 450 MKIII, I think it just looks "right"!
cooperplace
Postby cooperplace » Tue Oct 04, 2022 8:05 am
On the Vento, can someone please remind me of the size hex head needed to remove the timing access bolt thingie on the LHS? So that I can stick a degree wheel on.
And do I need to buy an Allen key of that size or can a bolt head be used?
Peter.
Postby themoudie » Tue Oct 04, 2022 1:13 pm
Aye Peter,
See attached image of a scan of my home made tool.
14mm across the flats, is the size of the hollow hex in the brass timing plug on the left-hand outer case.
Not having a 14mm hex key meant brazing up a 15mm nut and bolt and then filing the head of the bolt to fit. Being brass, the hollow hex maybe worn or deformed and consequently a true 14mm hex may prove a sloppy fit. I just use a 15mm ring spanner on the nut and have not had any problems using the tool.
I hope this helps.
cooperplace
Postby cooperplace » Wed Oct 05, 2022 10:33 am
Thank you.
The annoying thing is I have a spark plug tool with a 14mm hex head on it that would be perfect but I can't find it anywhere.
Postby Jordan » Fri Oct 07, 2022 9:40 pm
If you chop a piece from a 14mm Allen key, you can use it with a spanner, and it's a good small size for your bike's tool roll.
cooperplace
Postby cooperplace » Sat Oct 08, 2022 4:00 am
I ordered a 14mm Allen key on Ebay: $11 delivered.
cooperplace
Postby cooperplace » Thu Oct 20, 2022 3:20 pm
Does anyone know what size are the tiny nut and bolt that do the electrical connections to the points on a Vento? My smallest wrench is 6mm but seems too big on the nut. Or is just my bad eyes?
Users browsing this forum: DBDBrian and 119 guests
