New Amal Carb for 250 Monza
halfpast
Postby halfpast » Thu Jun 16, 2016 2:45 am
Hi all,
I figured I'd start a thread for the new carb I got for my bike - an Amal concentric 930. These are the setting I'll be running:
MAIN JET 220
PILOT JET 30
NEEDLE JET 105
NEEDLE POSITION 2
THROTTLE SLIDE 3.5
If anyone has suggestions please let me know, otherwise I'll post how the install (and running of the bike) turns out.
Nick
Re: New Amal Carb for 250 Monza
Postby Nick » Fri Jun 17, 2016 5:43 pm
Let us know how it runs.
At 30mm, the 930 seems a bit big for a 250 street bike. A smaller bore — 28 or even 26 — would give you better response in the low- and medium-rpm ranges. Also, a 926 will bolt on to the stock mounting studs with very little modification; a 930 is going to require a custom manifold of some sort.
If possible, maybe try to use a longer than stock intake manifold with a nicely tapered inlet tract.
Put a Mikuni on it!
halfpast
Postby halfpast » Sat Jun 18, 2016 7:31 am
Thanks Nick.
Did you mean a 626? I haven't been able to find any information on an Amal 926.
Nick
Postby Nick » Sun Jun 19, 2016 3:30 am
Yeah, a 626 is what you want. For jetting, look up the jetting for a Triumph T100R Daytona (500cc). It's really just two 250 singles stuck together, so that jetting should be pretty close for a 250 single like yours. 930 is too big.
Put a Mikuni on it!
halfpast
Postby halfpast » Mon Jun 20, 2016 9:37 pm
Founds some settings for the T100R, which are:
MAIN JET 150
NEEDLE JET 106
THROTTLE SLIDE 3.0
The 626 carb comes with a 160 main jet, 106 needle jet and a 3.0 slide so I think I'll just use those first and see how the bike runs, and then maybe swap for a 150 main jet later on to see if there's an improvement.
Postby Jordan » Mon Jun 20, 2016 10:26 pm
In my experience, an Amal 930 (30mm bore) works very well indeed on a roadgoing 250 Ducati with a 29mm inlet flange - a Mark3.
But it might not be perfect for the smaller Monza inlet. I don't have any data on this but an Amal 626 (26mm bore) might be a better match for a standard Monza. That has a 24mm inlet, doesn't it? Good idea to use Triumph Daytona settings as a start point for tuning.
Both 930 and 626 Amals, both called Concentric, have the same mounting flange detail, with 2 inch stud spacing. They easily attach directly to a Ducati 250 head, preferably with a heat insulating spacer.
halfpast
Postby halfpast » Mon Jun 20, 2016 11:55 pm
Thanks, Jordan. I'll be using one of these for a spacer:
http://www.eurojamb.com/ducati-bevel-in ... -2905.html
Postby Jordan » Tue Jun 21, 2016 11:44 am
halfpast wrote:Thanks, Jordan. I'll be using one of these for a spacer:
OK, but I see the hole size is 29mm, so there would be an undesirable gap between the carb and head.
Also available are simple Tufnol spacers with 26mm hole and 3mm thickness, from many sources including this one:
http://www.hitchcocksmotorcycles.com/am ... cellaneous
I've seen these Tufnol ones in various thicknesses between 1.5 to 20 mm.
halfpast
Postby halfpast » Sun Jul 03, 2016 4:05 am
Thanks Jordan for the suggestion. Unfortunately that outfit won't tell me shipping costs to the States until *after* i enter my credit card info on the website. And I haven't been able to find a place stateside that sells a 26mm gasket.
I hope to get the assembly together in the next few weeks and I'll post an update then. Thanks all.
halfpast
Postby halfpast » Wed Jul 06, 2016 12:29 am
Well, the carb has been installed. I went with a 150 main jet, 106 needle jet and a 3.0 slide. Took the bike for a couple runs up and down the street and it ran well, but the darn thing still doesn't want to idle. I also found that the motor won't start (even when warm) unless I use the tickler. So that made me think that the bowl wasn't being properly filled when at low RPM's. I therefore checked the petcocks and their flow, which seemed okay. Next was the tank vent. I opened the filler and saw the motor still wanted to die, so that's out. Anyone have any other thoughts?
(PS - photo taken before I put the air intake tube back on)
Users browsing this forum: No registered users and 28 guests
