What carb set up?
single-junk
Re: What carb set up?
Postby single-junk » Fri Nov 06, 2015 4:41 pm
This guy did:
viewtopic.php?f=3&t=1704&hilit=carb+setup&start=30
I think that's the way I'm going to go as well..
JJJ12345
Postby JJJ12345 » Thu Nov 19, 2015 7:46 pm
That is a nice set up. I have a 26mm Wassell I am going to try on my Sebring.
DesmoDog
Postby DesmoDog » Fri Nov 20, 2015 5:38 pm
On my 350 Bitsa I'm going with a Dellorto PHBH30 off of a Moto Guzzi. I got the manifold off of eBay, the carb just barely fits but it should work. Here it is just stuck in place with a filter and associated bits.
It more or less fits at this point so now I get to worry about porting the head to match and later figuring out the jetting/needle/slide for it...
JJJ12345
Postby JJJ12345 » Thu Dec 03, 2015 7:35 pm
The Wassell carb is no good, and I really don't know why. It would not deliver enough fuel(?). I bought a 26mm Keihin, bolted it on my 250 project, and so far I would say it works quite well. Easy start, idles, etc. I need to figure out an air cleaner set up. So far, I think it is a good value.
Postby Jordan » Thu Dec 03, 2015 11:01 pm
That looks like a neat compact installation.
cooperplace
Postby cooperplace » Fri Dec 04, 2015 6:01 am
pear0 wrote:For a 250 engine - a Mikuni VM 26 would work. Stock jetting to start .
Don't know about a manifold. Make one? TomA
I've got a VM26 on my 250 Monza, jetted as per Sudco recommendations. it's way too rich. I haven't yet tackled the problem of getting it right.
be nice, I'm not very bright.
JJJ12345
Postby JJJ12345 » Fri Jan 15, 2016 10:52 pm
Ok--- this is what I ended up with. 26mm Keihin. Bolts right on to the spacer by slightly enlarging the mounting holes. Jetted very close. 49mm K&N filter x 4" long. I think this is a great value for 120.00. Free shipping.
halfpast
Postby halfpast » Fri Jan 15, 2016 11:24 pm
Good deal.
Engine runs OK thru the RPM's?
Starts easy hot & cold?
JJJ12345
Postby JJJ12345 » Sun Jan 17, 2016 11:19 pm
Yes and yes
Users browsing this forum: No registered users and 154 guests
