Greetings,
I have an Amal Mk1 26mm carb (model 626/R300AL) fitted on my N/C 250 and would like to get jetting suggestions.
The carb came with the following Amal "factory standard" setting:
3 Cutaway Slide
160 Main Jet
106 Needle Jet
Premier Pilot Jet
Any help would be greatly appreciated.
-Adrian
Amal 26mm concentric on a N/C 250
narrow_monza
JJJ12345
Re: Amal 26mm concentric on a N/C 250
Are you bolting to the spacer or using a manifold? I would like to run one on my nc 250. Thanks. Any pics?
narrow_monza
I used a rubber spacer and an aluminum spacer (with fins). It might be overkill and I might go back to just a rubber spacer.
Here's a photo.
Here's a photo.
JJJ12345
Looks great. I think I am on the right track.
narrow_monza
Be careful not too over-tighten the mounting nuts. These carbs warp very easily.
Users browsing this forum: No registered users and 34 guests
