Throttle: Tommaselli Super Pratic or something more modern?
narrow_monza
Postby narrow_monza » Tue Aug 05, 2014 4:22 pm
Greetings,
I have the original style Tommaselli Super Pratic single pull throttle with the chain inside and no return spring mechanism.
Can someone recommend something more modern and functional that would be suitable for my narrow case 250 project?
I plan to use an Amal MkI Concentric 626 carb.
Adrian
Re: Throttle: Tommaselli Super Pratic or something more mode
Postby Jordan » Wed Aug 06, 2014 6:32 am
There's no return spring on any twistgrip throttle I've ever seen. The carburettor's slide spring normally does that job.
I like the Tommaselli item, as it's compact, unpainted aluminium with stainless steel cover plate, straight pull (easy on the cable) and correct for Ducati singles.
And, they are just capable of 30mm cable pull, so will suit any carb up to that size, including all fitted to our bikes as standard.
A negative is the sleeve that accepts the rubber grip is quite short, but there are ways to deal with that.
I also like this Amal type, which can be used with larger carbs:
http://www.groveclassicmotorcycles.co.u ... 1336-p.asp
narrow_monza
Postby narrow_monza » Wed Aug 06, 2014 1:22 pm
Jordan wrote:There's no return spring on any twistgrip throttle I've ever seen. The carburettor's slide spring normally does that job.
Thanks for the info Jordan!
Users browsing this forum: No registered users and 71 guests
