Hi to all and I'm new to Motoscrubs.
I race a Yamaha SR500 in pre 82 at our local club and was very pleased to acquire a 250 MK3 Ducati recently. It is a basket case but all major parts seem to be there. Been sitting in garage for 23 years. It will be turned into a track bike and hopefully fit into the Pre 63 class although the motor was built in 1964.
I've built a few frames so the starting point is to copy the exiting frame with lighter materials. (I also don't want to cut up a perfectly original frame) The existing frame with swing arm and triple clamps weigh in at 20KG, from experience, I should be able to get this around 12-13kg and with mount points for foot pegs and fairings included.
The head is a bit hammered so it needs a bit of weld here and there and new valve seats.
The rest of the motor looks fine.
I' not sure whether to post to a blog site on the rebuild or do a blog here.
Let me know.
http://marshland.co.nz/CB150Frame.html
Cheers Wallace
Turning a 250 basket case into a track bike.
marsheng
Re: Turning a 250 basket case into a track bike.
either way, I'd like to see the lightweight frame build
marsheng
OOPs 4 years have flown by !!!!!
I have a deadline of 4 weeks so I have to get it done. All the flat laser cut bits came yesterday and now busy putting them on.
Here are some photos. Guess I should tidy my workshop before taking them.
http://www.marshland.co.nz/ftp/Ducati250/MainTube.JPG
http://www.marshland.co.nz/ftp/Ducati250/Right.JPG
http://www.marshland.co.nz/ftp/Ducati250/Left.JPG
I'm adding outriggers to the swing arm and removed all else I don't need from the original frame. Some items are slightly larger so hopefully a lighter and stiffer frame.
All joints are Nickle bronzed. Really the best tube weld method there is. (Tigged just to keep it all together.)
Right back to the workshop.
looking good Wallace . next is the engine i presume .
Good Luck Eldert
Good Luck Eldert
PhilR
very nice, wish I was skilled enough to build a frame like this. looking forward to seeing future instalments.
Users browsing this forum: Boxprod and 71 guests
