Bevel Gear Damage Question
Posted: Tue Mar 13, 2012 3:42 pm
I apologize in advance for any terms I'm getting wrong, feel free to correct me. I need you guys' help to assess the damage and tell me what needs to be done and what can be saved.
We took off the bevel gear cover on our newly acquired Monza project bike last night to take a peek and here is what we found:
If you look at the lower gear in the 1 o'clock position, it is missing a tooth. Then, if you look just to the right of that, it looks like it took out some little chunks of the cylinder head casting. Also, is that galling on the end of the camshaft damage related to whatever happened?
We found this place online that sells the bevel shaft with gear:
http://www.classicitalianbikes.com/inde ... 93&lang=EN
Is this all we will need? Or does the bevel shaft gear have to be paired with a camshaft gear as a matched set?
Is the cylinder head able to be saved with the chunks missing?
How about the galling on the end of the cam?
Does this make the engine a parts donor or should it be saved?
Thanks for any insight you guys can give this newby to Ducati singles.
