175 crankcase repair
Posted: Tue Sep 06, 2011 4:19 pm
I bought a set of crankcases that I think are from the earlier 175 engine series- before the 175 used the 250 crankcases. Someone decided to convert it to a 250 by boring out the crankcase mouth, but it wasn't done very carefully- even if it had been done right the bore was too big to avoid breaking into the threaded holes for the cylinder bolts- here's a picture:
I'm a fool for this sort of project- repairing an abused part, so I'll probably try to fix it. This is a model of the problem:
And this is what I'd probably do to correct the problem:
But, I've never repaired a crankcase mouth, so I'd like to know if anyone has, and if there's a better solution. I would split the collar, plug weld it into place, and drill out the old threads for a TimeSert type of thread repair. The kerf removed from splitting the collar will probably be too big for the gasket surfaces to match up, but probalby not worth the effort of making 2 collars and cutting them 'off center'.
If anyone sees a problem with this let me know- it'll probably be winter before I start fooling around with it.
I did get the entire lower end, but no cylinder or head. I took a guess that the 175 cylinder sleeve would be 3mm thick like a 250, but I don't know what the dimensions of a 175 cylinder are- if anyone has measured a 175 cylinder I'd like to know the OD of the sleeve before I repair the cases to the wrong size.
And, if anyone has a 175 engine top end cluttering up their shop...
