Megacycle Cam 564-390
Posted: Thu Dec 09, 2010 3:49 pm
by ericpritchard
Does anyone have any experience or information on how to set up a Megacycle 564-390 cam for a widecase 350 race engine? The cam is based upon a Norris grind and no longer made by Megacycle. The spec sheet from Megacycle is not consistent with the cam, so any help would be appreciated.
Eric Pritchard
Re: Megacycle Cam 564-390
Posted: Thu Dec 09, 2010 5:09 pm
by Eldert
Hi Eric
Megacycle had the 564 390 for a while that was a Norris profile with .390 lift
this megacycle cam has the lobecentres way off . something around 95
if i remember correctly given timing was 51 / 77 , duration 308 and L.C. 103
Posted: Thu Dec 09, 2010 5:48 pm
by ericpritchard
Thanks for the info. The spec sheet states IN 51/77 EX 77/51 (open/close) with lobe centres IN 103 and EX 103 at 0.020" checking clearance.
The best I've managed so far is IN 61/46 EX 65/56 with lobe centres IN 83 EX 95 at 0.020" checking clearance.
There seems to be some doubt (at Megacyle, that is) as to exactly what the checking clearance should be...0.040", 0.020", 0.006"/0.012" or zero!
Also the spec sheet states valve lift at 0.416", but it measures 0.361" (at the valve tip).
Any thoughts, ideas welcomed!
Eric Pritchard
Posted: Thu Dec 09, 2010 6:03 pm
by Eldert
Hi Eric
i found my old timing notes
i took the readings at 1 mm lift with zero lash
intake opens 49 closes 52 duration 281 degrees L.C. 91.5 degrees
exhaust opens 47 closes 54 durations 281 degrees L.C. 86.5 degrees
my combined lobecentres are 178 degrees and so are yours
Posted: Thu Dec 09, 2010 6:59 pm
by ericpritchard
Many thanks for the info, Eldert. Very much appreciated.
Back to the shop...and I'll give it a try!!
Eric
