No spark on Electrex system -Fixed!
Posted: Sun Mar 08, 2026 8:35 pm
by ADiMizio
At the risk of this being yet another "What is the best kind of oil to use" type thread.....
I've recently installed an Electrex ignition system on my widecase 250/ I purchased this a long while back in 2019....life got in the way, so even though its new, I'm not sure any warranty would apply here outside of the 12 months from date of purchase.
I've installed it as per the included directions and schematic. I'm running a battery on a 12v system. All wiring is new on the bike, and all connections checked in the plug in connectors, which I installed with a proper crimp device. I've scoured the internet and compiled as many "check this" type actions as are out there. All resistance checks in the stator, the CDI, the coil, the sparkplug cap are within spec. However, I have a high reading of 10560 ohms from the two source wires that come from the hall effect ring, part HBP160. I have read that on some of these to see a range from 423 to 516 ohms. I have yet been unable to get a response back from Electrex customer support to find out if this indicates a bad unit, and in need of replacement. I hate to throw parts at this, but no amount of kicking is creating any spark, so I am at wits end. The LED on the unit does flash when kicked through, but no spark, no matter how weak.
Asking if anyone would know if there are any tests, or if it is know what the resistance range is on a working unit so I can get my bike back on the road. BTW, I've owned this bike since 1980. Its very much a Bitsa, but its been well loved over all these years.
Re: No spark on Electrex system
Posted: Sun Mar 08, 2026 9:09 pm
by Duccout
Firstly, where are you? Electrex World are very helpful, but understandably, for a tiny outfit, they are snowed-under with enquiries, plus they recently lost their top man to illness. I can't help you with technical info, but I did have the pulsar ring fail on my system recently, which I was able to find thanks to the help of Nigel Lacey.
I can offer a suggestion though that Nigel told me: try running a wire directly from the battery to the ignition system to cut out any chance of a problem in the ignition switch or wiring loom; other than that I can only say double check all connections again.
Posted: Sun Mar 08, 2026 9:26 pm
by ADiMizio
I'm in United States, California, Central Coast. Electrex support has responded to 2 of my email questions, which I greatly appreciate. They have yet to get back to me regarding the reading on the pick up ring resistance. I've tried to systematically approach the problem, and understand that they can only do so much. I 've gone through all the usual and everything else checks out, so short of reinstalling the original points system I guess its down to trying a new hall effect ring.
Posted: Tue Mar 10, 2026 10:15 pm
by LaceyDucati
Check the rotor, if the magnets are flat strips that is as per the latest version. Some early units had round magnets and they were problematic. I think a 2019 unit should be the later type, but worth checking.
The new Technical guy at Electrex is Aaron (Bobs is no longer there) and he is available for phone calls on Tuesdays, otherwise via email . Electrex provides some diagnosis information, but does not provide loads of resistance checks and I would advise against random testing as it could potentially cause damage. If the LED is switching then the pulsar ring is likely to be working. The pickup in the pulsar ring is a Hall effect switch and My guess is it's not something that will give a resistance and potentially could be damaged by trying to do a resistance check. That said if it switches (light going on and off) it's most likely working. Obviously all connections can be checked and coil tested via resistance along with a test of the generator coil (green and red wires) assuming this is a self generating system. Beyond that from experience it may be a faulty or blown CDI. We have experienced a few failures, but we sold many hundreds of kits, mostly without issue. See how you get on with Electrex, they should be able to sort things out. As has been said, they are a small company and not always the quickest to respond. Otherwise if you get no luck, maybe contact Doug at Bevel Single Parts. I still see emails there.
Posted: Sat Mar 14, 2026 4:25 pm
by ADiMizio
Nigel, thanks for the information. The magnets are the bar type, show good strength. I've been in touch with Electrex, Aaron has given me some good response to a couple emails and then went silent on one regarding the hall effect ring. They were super responsive on sales side though, and sent me off a new ring, which arrived in less than 1 week from the UK to California. Ill install it, check the rotor as you posted and then if still no spark replace the cdi. All connections multiple tested good. So, the story continues.....
Posted: Fri Mar 20, 2026 6:27 pm
by ADiMizio
Ok, with super fast international shipping from Electrex, I received the new CDI today and installed it. We have spark now! Issue solved. So old unit was bad out of the box, but because I didn't install it within the 1 year of it being ordered, the warranty didn't apply. Lesson learned for me.
Ill check my timing but it should fire up easily now...very bright spark!
Andy
Re: No spark on Electrex system -Fixed!
Posted: Tue Mar 24, 2026 8:26 am
by bendik
"For future reference" I am using the Electrex trigger w a Ignitech unit and that works fine. I established true TDC and then found the base setting on the rollers w a degree disc to be sure and then I can alter timing and curves via the Ignitech module.
Not sure its a great benefit if You have a working Electrex CDI though
Posted: Wed Mar 25, 2026 11:12 pm
by ADiMizio
bendik wrote:"For future reference" I am using the Electrex trigger w a Ignitech unit and that works fine. I established true TDC and then found the base setting on the rollers w a degree disc to be sure and then I can alter timing and curves via the Ignitech module.
Nice looking products. Thanks, I'll bookmark their website for future use.
Andy
